Hi all, I'm new to Umbraco and having a real difficult time....
I'm just wondering if someone can help me out here :'(
I created a navigation, which contains:
Home---About Me------Resume
I want to display Home and About me on the navigation, however it only displays About Me.
is it because Home contains About Me page?
here's my XSLT:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets "><xsl:output method="xml" omit-xml-declaration="yes" /><xsl:param name="currentPage"/><!-- Input the documenttype you want here --><xsl:variable name="level" select="1"/><xsl:template match="/"> <!-- Root Node --> <xsl:variable name="rootNode" select="$currentPage/ancestor-or-self::root" /> <!-- Homepage --> <xsl:variable name="homeNode" select="$rootNode/Kick-Home [@isDoc]" /> <!-- The fun starts here --><xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']"> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:attribute name="class"> <xsl:text>selected</xsl:text> </xsl:attribute> <xsl:value-of select="@nodeName"/> </a></xsl:for-each></xsl:template></xsl:stylesheet>
here's its page's link: http://umbraco.5am.co/kick.aspx
Thank you so much for reading this and have a great day !
oh! I found a solution !
i just had to add this line into the template !
<div id="nav"> <a href="/">Home</a></div>
Thank you so much Umbraco TV ! you Rock !
Upload image
Home page won't appear on my navigation
Home
---About Me
------Resume
here's my XSLT:
<xsl:stylesheet
version="1.0"
<!-- Root Node -->
<!-- Homepage -->
</xsl:attribute>
</a>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
<div id="nav">
