Having a problem with umbraco.library.RenderTemplate
I'm trying to use the "RenderTemplate" function in a macro. I am using the following code.
Important Notes: - I am using v 4.5 w/ <UseLegacyXmlSchema>true</UseLegacyXmlSchema> in umbracoSettings.config - This installation of umbraco is on a subdirectory - 1078 is a page node and 1080 is a template node. - This code worked for me previously. So, it should either be a problem with the 4.5 upgrade or the fact that this is on a subdirectory.
I've come to the conclusion, that I'm pretty sure the issue is related to Umbraco being hosted inside of a sub-directory. It is trying to find default.aspx in the root of the site instead of in umbraco's directory root.
Does anybody know where to change the path to this default.aspx?
Important Notes:
When i place this macro on a template, I get this error where the macro should be.
Does anybody know why this is happening?
Thank you so much!
