Hi,How can I pass variable using RenderMacroContent?Example:<xsl:variable name="Url" select="google.com"><xsl:value-of select="umbraco.library:RenderMacroContent('<?UMBRACO_MACRO macroAlias="Haeder" Url="[$Url]" ></?UMBRACO_MACRO>', $currentPage/@id)" disable-output-escaping="yes"/>Thanks,
kukuwka
Try concatenating the string:
<xsl:value-of select="umbraco.library:RenderMacroContent(concat('<?UMBRACO_MACRO macroAlias="Haeder" Url="[', $Url, ']" ></?UMBRACO_MACRO>'), $currentPage/@id)" disable-output-escaping="yes"/>
Thank you.
It works.
How pass variables using RenderMacroContent
Example:
kukuwka
<xsl:value-of select="umbraco.library:RenderMacroContent(concat('<?UMBRACO_MACRO macroAlias="Haeder" Url="[', $Url, ']" ></?UMBRACO_MACRO>'), $currentPage/@id)" disable-output-escaping="yes"/>Thank you.
It works.
