Please help in converting these 4.0.3 XSLT schema to 4.5.2
<xsl:variable name="homePagePath" select="umbraco.library:GetXmlNodeById($currentPage/ancestor-or-self::node[@level = '1'][@nodeTypeAlias = 'HomePage']/@id)"/>
<xsl:apply-templates select="$rootNodePath/node/node[@nodeName = $currentPage/@nodeName]/node[@nodeTypeAlias != 'Navigation']">
<xsl:when test="$currentPage/node[@nodeTypeAlias = $faqItemAlias]">
<xsl:for-each select="$rootNodePath/descendant::node/node">
<xsl:variable name="Parent" select="$currentPage/parent::node/@nodeTypeAlias"/>
Hi Ashok
Try theese:
<xsl:variable name="homePagePath" select="umbraco.library:GetXmlNodeById($currentPage/ancestor-or-self::HomePage[@level = '1']/@id)"/><xsl:apply-templates select="$rootNodePath/*[@isDoc]/*[@isDoc][@nodeName = $currentPage/@nodeName]/Navigation"><xsl:when test="$currentPage/*[@isDoc][name() = $faqItemAlias]"><xsl:for-each select="$rootNodePath/descendant::*[@isDoc]/*[@isDoc]"><xsl:variable name="Parent" select="$currentPage/parent::*[@isDoc]/name()"/>
Just from the top of my head, but I think they should work :)
/Kim A
Thanks Kim.
All seems OK except for
and <xsl:variable doesn't seem to like it.
Ahh, what!? :D
What doesn't seem to like what? And didn't the last one work or? If not, do you get any errors in Visual Studio when hovering the error?
Yeah - this can be a little misleading sometimes - but think of it as a static method in C# or similar; instead of calling name() on the node, feed the node into the name() function:
<xsl:variable name="Parent" select="name($currentPage/parent::*[@isDoc])" />
/Chriztian
Kim - yes, the last one didn't work and in VS when hovering displays the message - Expected end of the expression,............
Chriztian - Many thanks!. It worked.
Upload image
Need help to convert 4.0 XSLT schema to 4.5
Hi Ashok
Try theese:
/Kim A
Thanks Kim.
Ahh, what!? :D
/Kim A
/Chriztian
