  • Vincent DeCapite 64 posts 83 karma points
    Oct 14, 2010 @ 19:24
    Vincent DeCapite
    Problem opening up SWF from link
    From the template I have an option for the user to pick a media file to attach to the link as shown here in the productAnimation1 Section:
    In my template I have a piece of XSLT code that state:
    <xsl:if test="$product/data [@alias = 'productAnimation1'] != ''">
    <li><a href="{$product/data [@alias = 'productAnimation1']}" target="_blank">DeCapiteTEst</a></li>
    </xsl:if>
    When the page load though, it its getting the folder ID, but it is not getting the File Name so the actual file will open. I am getting this as the URL:
    http://10.1.20.195/product/productcat/productsubcat/3265 (no file name of this at the end)
    .. I am new to XSLT and passing variables like this so any help would be greatly appreciated.. Thanks
    Oct 14, 2010 @ 20:10
    Rich Green
    Hi Vincent,
    The problem you are having is that the ProductAnimation1 property holds the Node Id of the media item selected, so in your example your Snare_Release04.swf file will have a node id of 3265.
    To understand how to get the values from node Lee has a great post here http://blog.leekelleher.com/2009/11/30/how-to-use-umbraco-library-getmedia-in-xslt/
    You need to change your code to something like this:
     <xsl:variable name="mediaId" select="number($product/data[@alias='productAnimation1'])" />
        <xsl:if test="$mediaId &gt; 0">
            <xsl:variable name="mediaNode" select="umbraco.library:GetMedia($mediaId, 0)" />
            <xsl:if test="count($mediaNode/data) &gt; 0 and string($mediaNode/data[@alias='umbracoFile']) != ''">
                <a href="{$mediaNode/data[@alias='umbracoFile']}"><xsl:value-of select="$mediaNode/@nodeName"/><a/>
            </xsl:if>
        </xsl:if>
     Hope this helps
    Rich
    Oct 14, 2010 @ 20:19
    Vincent DeCapite
    Awesome That Worked... Thanks!
