Picture with a link to another picture uploted in a same node
well, I've made two upload controls, one for a thumbnail which is supposed to be shown as a part of a node and another one which should be opened directly in a browser to show image in full size when clicking on a thumbnail (in case someone is interested into saving picture and I don't like the idea to resize original size picture to fit into node).
I have no idea how to get the path to a uploaded photo, please help :(
First, just to confirm that you are using the Upload data-type, and not the media-picker data-type?
What is the property alias for the full-size photo?
Also, is your XSLT currently displaying the thumbnail images? As you shouldn't need to use a for-each to loop through the $currentPage, as there'd be only 1 iteration.
<xsl:for-each select="$currentPage">
<a href="location of a current()/photo">
<xsl:choose>
<xsl:when test="current()/photoThumbnail != ''">
<img src="{current()/photoThumbnail}" alt="{@nodeName}"/>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</a>
</xsl:for-each>
Thanks in advance.
Hi Xanthos,
Try this instead:
<xsl:if test="$currentPage/photoThumbnail != ''"> <a href="{$currentPage/photo}"> <img src="{$currentPage/photoThumbnail}" alt="{$currentPage/@nodeName}"/> </a> </xsl:if>Cheers, Lee.
Thank You, now it works as it was supposed so (thumbnail images were displayed before and I was using Upload data-type) :)
