  • Claushingebjerg 939 posts 2574 karma points
    Oct 27, 2010 @ 12:01
    Claushingebjerg
    problem with ancestor-or-self::node
    i have a problem in a menu i built, where i want set an "active" class on the <a> tag of the page and its parent when the page is selected.
    <xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id">
            <xsl:attribute name="class">active</xsl:attribute>
    xsl:if>
    a>
    does'nt apply "active" to any <a> , whereas the following sets the current page to "active" just fine
    <xsl:if test="$currentPage/@id = current()/@id">
    xsl:if>
    a>
    Oct 27, 2010 @ 12:03
    Claushingebjerg
    im running 4.5.2 by the way
  • Lee Kelleher 4026 posts 15836 karma points MVP 13x admin c-trib
    Oct 27, 2010 @ 12:08
    Lee Kelleher
    Hi Claushingebjerg,
    Do you know if you are using the new XML schema? If so, try this:
    <xsl:if test="$currentPage/ancestor-or-self::*[@isDoc]/@id = current()/@id">
    Cheers, Lee.
    Oct 27, 2010 @ 12:09
    Lee Kelleher
    By-the-way, you don't need to use the "current()" part either.  Just "@id" is fine - the XSLT understands the context of the condition.
    <xsl:if test="$currentPage/ancestor-or-self::*[@isDoc]/@id = @id">
    Oct 27, 2010 @ 12:29
    Claushingebjerg
    Grrrrrr damn schema....
    That did the trick, thanks :)
