  • sauritas 37 posts 57 karma points
    Nov 09, 2010 @ 16:08
    sauritas
    Logout using xslt + macro.net
    Hi!
    This is my umbraco info:
    Umbraco v4.0.3
    Microsoft SQL Server 2005
    IIS v5.1
    ASP.NET 3.5
    And this is my problem:
    We are developing a web site with umbraco. In fact, we are integrating an existing web application in Umbraco, using usercontrols. We have a .net macro that does the LOGOUT function, and we want to put it in the horizontal menĂº, that it's a xsl macro. I have read that you can't call a .net macro from a xsl macro.
    So, is there any way to do what I want? (See the figure below)
    Thanks!
  • Powellze 38 posts 73 karma points
    Nov 09, 2010 @ 16:33
    Powellze
    I have a couple of projects built this way. When I create a project I use the Settings > Templates and this is basically a MasterPage from .Net. Here you can add in your own controls etc.
    Or a different way is to use a Developer > Macro and browse your user control and add it in that way and specify this in your template.
    I think this PDF is old but will give you the general idea:
    http://umbraco.org/media/42a0202c-b0ba-4f84-bcf1-64dfd5230322-usingcontrolswithumbraco.pdf
    Let me know if you need any more on this.
    Tim
    Nov 09, 2010 @ 16:51
    sauritas
    In fact, I have my .net usercontrol in my Master Template, but I want that control to be shown in a horizontal dropdown menu, that is a xslt macro (that i also call in my master template). So, if I want to put my LOGOUT .net usercontrol as it were part of my horizontal dropdown menu...
    Thanks!
    Nov 09, 2010 @ 17:03
    Powellze
    Ok.., so first off you produce a horizontal navigation.
    Then in the navigation based upon X condition the logout 'control' needs to be added to this navigation?
    What is in the logout control?
    I think what you are doing needs to be done at a different level, what you are aiming for I dont think you can get at. Maybe a little more explanation might get me to what you are after.
    Tim
    Nov 09, 2010 @ 17:16
    sauritas
    Yes, that is what I want.
    In my logout control I have the methods needed to logout in umbraco and in my own application (we have developed our own member control).
    Maybe I have to think in a different way... I don't know... in the original application, I did it by showing or hidding a <div> in the master template depending if a user was logged (in the cs code)....
