  • dcrug 23 posts 20 karma points
    Jan 08, 2009 @ 23:40
    dcrug
    Sitemap Issue
    Does anyone know if it is possible to start the sitemap at a specific node and display all levels under that. For example my content is like this.
    en
    Home
    Page1
    Page2
    Page3
    I do not want include en in the sitemap list.
    So i want to display everything under home including home.
    Jan 08, 2009 @ 23:56
    Morten Bock
    Could you include your current sitemap xlst code?
  • praveen 113 posts 164 karma points
    Mar 27, 2012 @ 05:30
    praveen
    HI There,
    I have installed Google Sitemap for Umbraco 4 (jesper.com) package.
    When I try to http://yourdomain.com/GoogleSiteTree.aspx
    I get the following error:
    Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
    Invalid at the top level of the document. Error processing resource 'http://nn.gorillahq.com/GoogleSiteTree.aspx'. Line 1,...
    Error parsing XSLT file: \xslt\GoogleSiteTree.xslt
    Look at the full description here:
    http://our.umbraco.org/forum/getting-started/installing-umbraco/30198-Google-Sitemap-does-not-work
  • Grant Thomas 291 posts 324 karma points
    Mar 27, 2012 @ 12:03
    Grant Thomas
    Praveen, this post is not related to your topic per se - I understand your urge to find help, but you're borderline spamming the forums.
    Mar 27, 2012 @ 21:54
    praveen
    Hi Chief, thanks for the note, apologies for borderline spamming,
    and thanks for understanding my urge :) for a solution.
    I really need help here, I am asking a silly question, nobody seem to resopond!!
    Regards
