  • Mikael Mørup 297 posts 326 karma points
    Jan 27, 2009 @ 12:04
    Mikael Mørup
    XSLT pageproperti reference problem
    I have this XSLT as par of my side navigation macro:
  • The links are generated and works just fine. The part that doesen't work is this:
    Why can't i reference my spaceabove property the way i try to do ?
    And what is the correct way to do it ?
    Mikael
Copy Link
    Jan 27, 2009 @ 12:48
    Dirk De Grave
    Hi Mikael,
    Looks ok to me! Although, I mostly use this construct:
    [code]
    Copy Link
    Dirk De Grave
    And I'd wrap the 'space' literal in a
    Copy Link
    Jan 27, 2009 @ 13:23
    Mikael Mørup
    thanks for the reply.
    Unfortunately it deosen't seem to solve my problem.
    I tried using the string cast and i checked that the spelling of the property alias is correct.
    Mikael
    Copy Link
    Jan 27, 2009 @ 13:28
    Mikael Mørup
    Uups
    i think i have a caching issue, after republishing, it did seem to help.
    Copy Link
  • Please Sign in or register to post replies
