Funny, I just got that same error for the first time not 5 minutes ago. You just need to add the attribute first - so move the text between the attribute and the anchor.
Hi All , I am getting the same error, my xslt is given below , i found the error on id which is bold in below xslt . I tried to put <xsl:if test="id != ''"> before this but it always return false and not control not enter in if condtion.please help.
I want to post solution of my query. i set a condition postion()=1, which bring two rows at once for my dropdown control.if i set postion()=2 , it gave the same error.
Hi , my other xslt also give error (Attribute and namespace nodes cannot be added to the parent element after a text, comment, pi, or sub-element node has already been added.) on bold syntax given below, it looks like given below
Help adding » to XSLT
Using Umbraco 4.5.2
I'm trying to style the output of this XSLT
Now whenever I try and use:
<xsl:text>»</xsl:text> or »
I get the following error:
Stumped!
Looking around on the forums there aren't too many similar cases. Hope one of you experts pulls the rabbit outta the hat for me!
Owen
Thank you Jeff!
Owen
<xsl:for-each select="PayoutTimePeriod">
<xsl:attribute name="id">
<xsl:value-of select="compare:returnName(@id,@jointApp,@feature)"/>
</xsl:attribute>
<xsl:attribute name="name">
</xsl:attribute>
</xsl:for-each>
error is - Attribute and namespace nodes cannot be added to the parent element after a text, comment, pi, or sub-element node has already been added.
<xsl:if test="position() = 1">
</xsl:attribute>
</xsl:attribute>
</xsl:if>
</xsl:for-each>
<xsl:for-each select="Features/ProductName">
<xsl:variable name="FileName">
<xsl:value-of select="@fileName"/>
</xsl:variable>
<td align="center">
<xsl:choose>
<xsl:when test="@fileName!=''">
<xsl:element name="a">
<xsl:attribute name="onclick">OpenCarrierOutline('<xsl:value-of select="$ServerName"/>','<xsl:value-of select="$FileName"/>');</xsl:attribute>
<xsl:attribute name="href">#</xsl:attribute>
<xsl:value-of select="."/>
</xsl:element>
</xsl:when>
</td>
</xsl:for-each>
please help
kapil Gupta
INDIA
