Another update. I realized that I cannot base my navigation from the current page because if I navigate within my subnav the "current page" is no longer a level 2 node.
So I have gone ahead and made the following changes:
<xsl:template match="/"> <!-- Sub Nav Heading --> <h1> <a href="{umbraco.library:NiceUrl($currentPage/ancestor-or-self::*[@level = 2]/@id)}"><xsl:value-of select="$currentPage/ancestor-or-self::*[@level = 2]/@nodeName" /></a> </h1> <xsl:if test="count($currentPage/* [@isDoc and string(umbracoNaviHide) != '1']) > 0"> <ul> <xsl:for-each select="$currentPage/descendant-or-self::*[@level=3 and @isDoc and string(data [@alias='umbracoNaviHide']) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a> <ul class="subnav"> <xsl:for-each select="$currentPage/descendant-or-self::*[@level=4 and @isDoc and string(data [@alias='umbracoNaviHide']) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a> </li> </xsl:for-each> </ul> </li> </xsl:for-each> </ul> </xsl:if>
</xsl:template>
</xsl:stylesheet>
Now this gives me the Parent Node (level 2) and the Level 3 children of the Parent Node. However the level 4 children are listed underneath every Level 3 Node, instead of under their correct parent.
Still struggling with this, I am close as I am properly linking tier 2 and 3 nodes, just big problems on the tier 4. It seems that every tier 4 node found is being listed under all of the tier 3 node, instead of just the one its actually a child of.
Do you have a working HTML/CSS prototype of the navigation? Maybe we should have a look at that first and then decide how to best generate the desired output.
<xsl:template match="/"> <!-- Sub Nav Heading --> <h1> <a href="{umbraco.library:NiceUrl($parentNode/ancestor-or-self::*[@level = 2]/@id)}"><xsl:value-of select="$parentNode/ancestor-or-self::*[@level = 2]/@nodeName" /></a> </h1> <xsl:if test="count($parentNode/* [@isDoc and string(umbracoNaviHide) != '1']) > 0"> <ul> <xsl:for-each select="$parentNode/descendant-or-self::*[@level=3 and @isDoc and string(data [@alias='umbracoNaviHide']) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a> <ul class="subnav">
//THIS IS WHERE THE PROBLEM LIES <xsl:for-each select="$parentNode/descendant::*[@level=4 and @isDoc and string(data [@alias='umbracoNaviHide']) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a> </li> </xsl:for-each> </ul> </li> </xsl:for-each> </ul> </xsl:if>
</xsl:template>
</xsl:stylesheet>
From my structure below you can see that the "Videos" section has two children "Campbell River Video" and "Test Video sub Page"
These should be only listed under the Videos section, but instead is being listed under all Level 3 nodes. I need a way of enforcing that the nodes only be printed under their parent.
Thanks for the help, hopefully this will lead to a more clear understanding.
Owen
PS: Yes, I have wrote this sub-nav in ASP.NET and had it working, however I would like to use XSLT as its a little tidier and generally there is more support for it here on the forums!
Have you had a look at the link Chriztian posted earlier? It's really not more advanced thant that. If it's getting the "Home" node that's causing the problem, then hardcode it into the file.
I really urge you to take a look at Chriztians sample. That's a good way to achieve your goal I think.
This should work i think. The problem was that the 2nd loop wasn't being related to the 1st loop because you were using the $parentNode variable which was pulling it out of the loop and starting again. If you're in a loop then the nestedloop only needs to be relative to the outerloop. So if you're in the level 3 loop then you can be safe to assume that the next level down is 4 so you can just use the *[@isDoc] to loop the next level.
Haven't tested it though so could be an error or something in there.
Sub Navigation Problem
Using Umbraco 4.5.2 and having some difficulties writing a XSLT for my Sub Navigation.
Here is my tree:
Now I am a little unclear on levels, but my understanding is:
Home - Level 1
News and Media - Level 2
Video - Level 3
Campbell River Video - Level 4
Now output is like this:
So far I am able to output the Level 2 Nav ($currentPage name and id)
But from there I am stumped. Here is my current XSLT:
Any help or suggestions would be great! Still fairly new to XSLT.
Owen
I have managed to get the following output:
using the following XSLT:
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:tagsLib="urn:tagsLib" xmlns:BlogLibrary="urn:BlogLibrary"
exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets tagsLib BlogLibrary ">
<h1>
<a href="{umbraco.library:NiceUrl($currentPage/@id)}"><xsl:value-of select="$currentPage/@nodeName"/></a>
</h1>
<ul>
<xsl:for-each select="$currentPage/* [@level=3 and @isDoc and string(data [@alias='umbracoNaviHide']) != '1']">
<li>
<xsl:if test="count($currentPage/*/* [@level=4 and @isDoc and string(umbracoNaviHide) != '1']) > 0">
<ul class="subnav">
<xsl:for-each select="$currentPage/*/* [@level=4 and @isDoc and string(data [@alias='umbracoNaviHide']) != '1']">
<li>
</li>
</xsl:for-each>
</ul>
</xsl:if>
</li>
</xsl:for-each>
</ul>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Now the problem is that the 4th tier child nodes are being printed for every 3rd child, instead of just only their parent. How can I constrain this?
Owen
Any help would be much appreciated.
Owen
Heres a SS:
Hi Owen,
Also: Take a look at my answer here: http://our.umbraco.org/forum/developers/xslt/14812-Navigation-help?p=0#comment54648 - that might actually be a good starting point...
/Chriztian
Hi Owen,
check this code. You will have only to adjust for your needs. Hope it helps!
/PRK
Thank you for your comments, I have been playing around with my XSLT a little more and I feel that I am very close to getting the desired solution.
I have omitted some of the generic code but my latest XSLT looks like this:
Owen
Still stumped, and I've tried a lot of different approaches and read a lot of forums.
No one has ever dealt with something like this before?
Owen
Hi Owen
<xsl:variable name="parentNode" select="$currentPage/ancestor-or-self::*[@isDoc and @level = 2]"/> <xsl:template match="/"> <!-- Level 2 --> <h1> <a href="{umbraco.library:NiceUrl($parentNode/@id)}"> <xsl:value-of select="$parentNode/@nodeName"/> </a> </h1> <!--Level 3--> <xsl:if test="count($parentNode/*[@isDoc and string(umbracoNaviHide)!='1']) > 0"> <ul> <xsl:for-each select="$parentNode/*[@isDoc and string(umbracoNaviHide)!='1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> <!--Level 4--> <xsl:if test="count(*[@isDoc and string(umbracoNaviHide)!='1']) > 0"> <ul class="subnav"> <xsl:for-each select="*[@isDoc and string(umbracoNaviHide)!='1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each> </ul> </xsl:if> </li> </xsl:for-each> </ul> </xsl:if> </xsl:template>Rory!
You are my savior! Thank you so much, I completely understand now!
Thanks again!
Owen +1
