Using Umbraco 4.5.2 and having some difficulties writing a XSLT for my Sub Navigation.
Here is my tree:
Now I am a little unclear on levels, but my understanding is:
Home - Level 1
News and Media - Level 2
Video - Level 3
Campbell River Video - Level 4
Now output is like this:
So far I am able to output the Level 2 Nav ($currentPage name and id)
But from there I am stumped. Here is my current XSLT:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:tagsLib="urn:tagsLib" xmlns:BlogLibrary="urn:BlogLibrary" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets tagsLib BlogLibrary "><xsl:output method="xml" omit-xml-declaration="yes" /><xsl:param name="currentPage"/><xsl:template match="/"> <!-- Sub Nav Heading --> <h1> <a href="{umbraco.library:NiceUrl($currentPage/@id)}"><xsl:value-of select="$currentPage/@nodeName"/></a> </h1> <ul> <xsl:for-each select="$currentPage/ancestor-or-self::node [@level=2]/node [string(data [@alias='umbracoNaviHide']) != '1']"> <xsl:if test="number($currentPage/@level)=3"> <xsl:for-each select="$currentPage/child::node [@level=3]/node [string(data [@alias='umbracoNaviHide']) != '1']"> <li> <a href="{umbraco.library:NiceURL($currentPage/@id)}"><xsl:value-of select="$currentPage/@nodeName"/></a> </li> </xsl:for-each> </xsl:if> </xsl:for-each></ul></xsl:template></xsl:stylesheet>
Any help or suggestions would be great! Still fairly new to XSLT.
Owen
Sub Navigation Problem
Here is my tree:
Home - Level 1
Video - Level 3
Owen
