Can anybody see whats wrong with this
<xsl:variable name="media" select="umbraco.library:GetMedia(/macro/imageID, 0)" /><img src="{$media/umbracoFile}" />
the macro throws an error...
If i do a simple
<xsl:value-of select="/macro/imageID"/>
i get "/media/41/suni.gif152793150gif" so there is data present inside the scope...
Hi Claus,
Looks like it's a "mediaCurrent" variable, right?
Those already return the XML, so you can just do:
<xsl:variable name="media" select="/macro/imageID" /> <img src="{$media/umbracoFile}" />
/Chriztian
Yes, its a mediaCurrent, but it still doesnt work for some reason...
when doing a <xsl:copy-of select="$media/umbracoFile"/> i get nothing
<xsl:copy-of select="$media"/> returns /media/41/suni.gif152793150gif ?!? strange...
Hi Claus
But isn't it the path that you need? Then you will just need the $media variable, right?The output looks like you're using the "upload" datatype on your page...and then I guess it all makes sense (if i'm right off course :-))
I also had this problem. Somehow I had a problem with putting it into a variable, but getting it directly worked:
You could try something like this:
/macro/imageID/Image/umbracoFile
Now you get the value directly from the macro instead of the variable. Worked for me.
Jeroen
Thanks Jeron, that worked
Ah ok - might be getting more than we asked for, so to speak - what does this give you:
<xsl:copy-of select="/macro" />
Hopefully something along the lines of:
<macro> <imageID> <Image> <umbracoFile>/media/41/suni.gif</umbracoFile> <umbracoWidth>...</umbracoWidth> <!-- More image properties --> </Image> </imageID> </macro>
i get
<macro> <link>1064</link> <imageID> <Image id="1076" version="d11a7686-c0c7-4124-856a-311d62dc65aa" parentID="1075" level="2" writerID="0" nodeType="1032" template="0" sortOrder="1" createDate="2010-11-23T11:43:19" updateDate="2010-11-23T11:43:18" nodeName="test" urlName="test" writerName="Administrator" nodeTypeAlias="Image" path="-1,1075,1076"> <umbracoFile>/media/41/suni.gif</umbracoFile> <umbracoWidth>152</umbracoWidth> <umbracoHeight>79</umbracoHeight> <umbracoBytes>3150</umbracoBytes> <umbracoExtension>gif</umbracoExtension></Image> </imageID></macro>
Problem with getmedia 4.5.2
If i do a simple
<xsl:value-of select="/macro/imageID"/>i get "/media/41/suni.gif152793150gif" so there is data present inside the scope...
Hi Claus,
<xsl:variable name="media" select="/macro/imageID" /> <img src="{$media/umbracoFile}" />/Chriztian
Hi Claus
Jeroen
<macro> <imageID> <Image> <umbracoFile>/media/41/suni.gif</umbracoFile> <umbracoWidth>...</umbracoWidth> <!-- More image properties --> </Image> </imageID> </macro>/Chriztian
i get
