  • Ol 7 posts 27 karma points
    Nov 24, 2010 @ 16:08
    Ol
    Problem with 4 level menu
    Hi, everyone
    I have code of 4 level-menu:
    <!DOCTYPE xsl:stylesheet [
      <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
                            version="1.0"
      <xsl:template match="/">
        <!-- The fun starts here -->
        <div id = "panel">
          <ul class="dropdown" id="menu">
            <!-- checking every node in navigation -->
            <xsl:for-each select="$currentPage/ancestor-or-self::node [@level=1]/node [string(data [@alias='umbracoNaviHide']) != '1']">
              <li class="static">
                <div class="centerMenu">
                  <div class="liSpn">
        <!--*********************************** if current node have level 2 items, insert UL ***********************************-->
                <ul style="background:url(/media/79999/submenu.png) 0 0 no-repeat">
                  <xsl:if test="current()/@level = 2 and child::node()[*] !=''">
                    <xsl:for-each select="current()/node [string(data [@alias='umbracoNaviHide']) != '1']">
                      <xsl:choose>
                        <xsl:when test="current()/child::node()[*] !=''">
                          <xsl:choose>
                            <xsl:when test="string-length(current()/@nodeName) > 20">
                              <li class="submenu">
                                <a class="longA" href="{umbraco.library:NiceUrl(@id)}">
                                </a>
                                <!--*********************************** if current node have level 3 items, insert UL ************************************ -->
                                <xsl:if test="current()/@level = 3 and child::node()[*] !=''">
                                  <ul style="background:url(/media/79999/submenu.png) 0 0 no-repeat; border-left: solid 1px white; margin-top:-1px;">
                                      <xsl:choose>
                                          <xsl:choose>
                                                </a>
                                                <!--*********************************** if current node have level 4 items, insert UL ************************************ -->
                                                <xsl:if test="current()/@level = 4 and child::node()[*] !=''">
                                                      <xsl:choose>
                                                          <xsl:choose>
        </a>
                                                              </li>
                                                            </xsl:when>
                                                            <xsl:otherwise>
        <a class="liA" href="{umbraco.library:NiceUrl(@id)}">
        </a>
                                                              </li>
                                                            </xsl:otherwise>
                                                          </xsl:choose>
                                                        </xsl:when>
                                                        <xsl:otherwise>
                                                          <xsl:choose>
                                                              <li class="submenu1">
        </a>
                                                              </li>
                                                            </xsl:when>
                                                            <xsl:otherwise>
        </a>
                                                              </li>
                                                            </xsl:otherwise>
                                                          </xsl:choose>
                                                        </xsl:otherwise>
                                                      </xsl:choose>
                                                    </xsl:for-each>
                                                  </ul>
                                                </xsl:if>
                                              </li>
                                            </xsl:when>
                                            <xsl:otherwise>
                                                </a>
                                                      <xsl:choose>
                                                          <xsl:choose>
        </a>
                                                              </li>
                                                            </xsl:when>
                                                            <xsl:otherwise>
        </a>
                                                              </li>
                                                            </xsl:otherwise>
                                                          </xsl:choose>
                                                        </xsl:when>
                                                        <xsl:otherwise>
                                                          <xsl:choose>
        </a>
                                                              </li>
                                                            </xsl:when>
                                                            <xsl:otherwise>
        </a>
                                                              </li>
                                                            </xsl:otherwise>
                                                          </xsl:choose>
                                                        </xsl:otherwise>
                                                      </xsl:choose>
                                                    </xsl:for-each>
                                                  </ul>
                                                </xsl:if>
                                              </li>
                                            </xsl:otherwise>
                                          </xsl:choose>
                                        </xsl:when>
                                        <xsl:otherwise>
                                          <xsl:choose>
                                                </a>
                                              </li>
                                            </xsl:when>
                                            <xsl:otherwise>
                                                </a>
                                              </li>
                                            </xsl:otherwise>
                                          </xsl:choose>
                                        </xsl:otherwise>
                                      </xsl:choose>
                                    </xsl:for-each>
                                  </ul>
                                </xsl:if>
                              </li>
                            </xsl:when>
                            <xsl:otherwise>
                                </a>
                                      <xsl:choose>
                                          <xsl:choose>
                                                </a>
                                                      <xsl:choose>
                                                          <xsl:choose>
        </a>
                                                              </li>
                                                            </xsl:when>
                                                            <xsl:otherwise>
        </a>
                                                              </li>
                                                            </xsl:otherwise>
                                                          </xsl:choose>
                                                        </xsl:when>
                                                        <xsl:otherwise>
                                                          <xsl:choose>
        </a>
                                                              </li>
                                                            </xsl:when>
                                                            <xsl:otherwise>
        </a>
                                                              </li>
                                                            </xsl:otherwise>
                                                          </xsl:choose>
                                                        </xsl:otherwise>
                                                      </xsl:choose>
                                                    </xsl:for-each>
                                                  </ul>
                                                </xsl:if>
                                              </li>
                                            </xsl:when>
                                            <xsl:otherwise>
                                                </a>
                                                      <xsl:choose>
                                                          <xsl:choose>
        </a>
                                                              </li>
                                                            </xsl:when>
                                                            <xsl:otherwise>
        </a>
                                                              </li>
                                                            </xsl:otherwise>
                                                          </xsl:choose>
                                                        </xsl:when>
                                                        <xsl:otherwise>
                                                          <xsl:choose>
        </a>
                                                              </li>
                                                            </xsl:when>
                                                            <xsl:otherwise>
        </a>
                                                              </li>
                                                            </xsl:otherwise>
                                                          </xsl:choose>
                                                        </xsl:otherwise>
                                                      </xsl:choose>
                                                    </xsl:for-each>
                                                  </ul>
                                                </xsl:if>
                                              </li>
                                            </xsl:otherwise>
                                          </xsl:choose>
                                        </xsl:when>
                                        <xsl:otherwise>
                                          <xsl:choose>
                                                </a>
                                              </li>
                                            </xsl:when>
                                            <xsl:otherwise>
                                                </a>
                                              </li>
                                            </xsl:otherwise>
                                          </xsl:choose>
                                        </xsl:otherwise>
                                      </xsl:choose>
                                    </xsl:for-each>
                                  </ul>
                                </xsl:if>
                              </li>
                            </xsl:otherwise>
                          </xsl:choose>
                        </xsl:when>
                        <xsl:otherwise>
                          <xsl:choose>
                                </a>
                              </li>
                            </xsl:when>
                            <xsl:otherwise>
                                </a>
                              </li>
                            </xsl:otherwise>
                          </xsl:choose>
                        </xsl:otherwise>
                      </xsl:choose>
                    </xsl:for-each>
                  </xsl:if>
                </ul>
              </li>
            </xsl:for-each>
            <li style="background-image:url(/media/78975/lastEl.png);background-repeat:no-repeat;margin:0px;padding:0px;color:White;height:45px;width:90px;" id="col6">
              <span class="liSpn"></span>
            </li>
          </ul>
      </xsl:template>
    </xsl:stylesheet>
    With this code here is what I get:
    But I need:
    Can someone help to find mistake?
    Nov 24, 2010 @ 16:59
    Hi OI
    I will really urge you to have a look at the example that Chriztian has provided in this post: http://our.umbraco.org/forum/developers/xslt/14812-Navigation-help
    The stuff you're posting is way too cumbersome and it should really not be *that* hard. :-)
    I think you'll find it a better way to do your navigation and it's much easier to understand what's going on.
    Hope this helps.
    Nov 25, 2010 @ 11:51
    Ol
    Thanks, Jan!
    It finds all nodes in any level. It's already very good. Now t's left to deal with styles)
