  • Przemo 2 posts 22 karma points
    Dec 01, 2010 @ 20:08
    Przemo
    xsl:when problem
    i'm trying to build  menu.
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
      exclude-result-prefixes="msxml
    umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes
    Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings
    Exslt.ExsltSets "
    <xsl:variable name="level" select="1"/>
    <xsl:template match="/">
    <!-- The fun starts here -->
      <ul>
        <li> <a href="/">Start</a></li>
        <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
          <li>
            <a>
              <xsl:attribute name="href">
                <xsl:choose>
                  <xsl:when test="count(./*[@isDoc]) = 1">
                    <xsl:value-of select="umbraco.library:NiceUrl(./node/@id)" />
                  </xsl:when>
                  <xsl:otherwise>
                    <xsl:value-of select="umbraco.library:NiceUrl(@id)" />
                  </xsl:otherwise>
                </xsl:choose>
              </xsl:attribute>
              <xsl:value-of select="menuTitle"/>
            </a>
          </li>
        </xsl:for-each>
      </ul>
    </xsl:template>
    </xsl:stylesheet>
    why after change  "=" to "&gt;" or ">" in line <xsl:when test="count(./*[@isDoc] =1">  i've got error System.OverflowException: Value was either too large or too small for an Int32.?
  • Sebastian Dammark 583 posts 1407 karma points
    Dec 01, 2010 @ 20:58
    Sebastian Dammark
    What is the value of count(./*[@isDoc]) ?
    Dec 01, 2010 @ 21:13
    Have you tried to check the "skip error testing" - even though you get the error in the editor it might be working if you skip the error testing. It has to do with the values first being accessible on runtime I guess...
    Dec 01, 2010 @ 21:38
    Kim Andersen
    I think the error occours because you are using the "node" in your xpath. Try changing this line:
    To this:
    <xsl:value-of select="umbraco.library:NiceUrl(./*[@isDoc]/@id)" />
    /Kim A
