  • Andreas Gurtner 7 posts 20 karma points
    Mar 25, 2009 @ 14:52
    Andreas Gurtner
    Problem with integer variable
    Hi all
    I've got a strange problem with an XSLT script which lists my subnavigation. For the navigation title I use a variable which stores the node from the second level:
    [code]
    [/code]
    Looks fine, but when I save this the following error occours:
    [quote]System.OverflowException: Value was either too large or too small for an Int32.
    at System.Convert.ToInt32(Double value)
    at System.Double.System.IConvertible.ToInt32(IFormatProvider provider)
    at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
    at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
    at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlSequenceWriter results)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer, Boolean closeWriter)
    at System.Xml.Xsl.XmlILCommand.Execute(IXPathNavigable contextDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter results)
    at System.Xml.Xsl.XmlILCommand.Execute(IXPathNavigable contextDocument, XmlResolver dataSources, XsltArgumentList argumentList, TextWriter results)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    [/quote]
    If I change the value from $HomeNodeLevel to 1 the script is saving without a problem.
    But when I save the script without the xslt tests and test it on the website it works fine!
    Can anyone tell me why this correct script responses this error and if is there a workaround?
    Andy
  • Petr Snobelt 923 posts 1535 karma points
    Mar 26, 2009 @ 09:05
    Petr Snobelt
    Hi, you can try
    Petr
