  • Mikkel Johansen 116 posts 292 karma points
    Mar 26, 2009 @ 13:46
    Mikkel Johansen
    Side Navigation - 3 levels !
    I have no problem making a 2 level side navigation. But how do I make a XSLT that handles a navigation with 3 levels.
    I am looking for a solution that only show the child-nodes when the parent is opened/in the breadcrumb.
    Example steps of output:
    No levels has been clicked
    [code]
    node1
    node2
    node3
    [/code]
    Node2 has been clicked
    [code]
    node1
    node2
    node2.1
    node2.2
    node2.3
    node3
    [/code]
    Node2.2 has been clicked
    [code]
    node1
    node2
    node2.1
    node2.2
    node2.2.1
    node2.2.2
    node2.2.3
    node2.3
    node3
    [/code]
    Node3 has been clicked
    [code]
    node1
    node2
    node3
    node3.1
    node3.2
    node3.3
    [/code]
    Can any body help me.
    Thanks in advance
    Mikkel
  • Finn 86 posts 50 karma points
    Mar 26, 2009 @ 15:38
    Finn
    This works fine for me:
    http://forum.umbraco.org/yafpostst3421Creating-a-3rd-and-dare-I-say-4th-level-navigation.aspx
    Look at the last post.
    /Finn
    Mar 27, 2009 @ 13:29
    Mikkel Johansen
    Hi Finn
    thanks. It works just like it should.
    /Mikkel
