  • MartinB 411 posts 512 karma points
    Dec 07, 2010 @ 19:14
    MartinB
    Level 0 Navigation (Top level nodes)
    Hi there
    Been searching the forums the last hour looking for an answer to how i get my level 0 (root) nodes liste with xslt for a toplevel navigation menu in the old schema.
    Structure looks like this example:
    - Domain 1
       - Home
       - About
         - Vision
    - Domain 2
       - Home
       - About
         - Vision
    - Domain 3
       - Home
       - About
         - Vision
    I started using the Prototype Navigation xslt, but when i set level=1 i get the nodes below Domain 1. If i set it to 0 i get nothing.
    XSLT:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <!-- Input the documenttype you want here -->
    <!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
    <!-- Use div elements around this macro combined with css -->
    <!-- for styling the navigation -->
    <xsl:variable name="level" select="2"/>
    <xsl:template match="/">
    <!-- The fun starts here -->
    <ul>
    <xsl:for-each select="$currentPage/ancestor-or-self::node [@level=$level]/node [string(data [@alias='umbracoNaviHide']) != '1']">
    <li>
    <xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id">
    <!-- we're under the item - you can do your own styling here -->
    <xsl:attribute name="style">font-weight: bold;</xsl:attribute>
    </xsl:if>
    </a>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:template>
    </xsl:stylesheet>
    MartinB
    Gah, sry for the double post :(
    Dec 07, 2010 @ 19:27
    MartinB
    Got it!
    <xsl:for-each select="$currentPage/ancestor-or-self::node [@level=$level]/../node [string(data [@alias='umbracoNaviHide']) != '1']">
    Dec 07, 2010 @ 19:42
    Rich Green
    Hi Martin,
    Glad you got it sorted!
    In future you might like to structure your site so your pages are all under 'Home' of each site, like this:
     Domain 1
       - Home
       - About
         - Vision
    - Domain 2
       - Home
       - About
         - Vision
    - Domain 3
       - Home
       - About
         - Vision
    Your structure (I imagine) was the reason that the navigation xslt wasn't pulling out all the nodes.
    Rich
    Dec 07, 2010 @ 20:00
    MartinB
    Hi Rich
    With the structure you suggest, how do you go about not hardcoding the Home link since it's on a different level than the other subnodes?
    Dec 07, 2010 @ 20:34
    Rich Green
    Hi Martin,
    This code should work (place it outside of the navigation loop)
    <li>
        <a href="/">
            <xsl:if test="$currentPage/@level=1">
                <xsl:attribute name="class">active</xsl:attribute>
            </xsl:if>
            <xsl:value-of select="$currentPage/ancestor-or-self::node/@nodeName"/>
        </a>
    </li>
    Rich
    Dec 07, 2010 @ 21:27
    MartinB
    Oh, never seen that before.
    I'll bookmark this one and try it out for my next project.
    Thanks for commenting!
    Dec 10, 2010 @ 09:12
    MartinB
    That really didn't work out for me all that well.
    When i change the level variabel to 2 in the original xslt in order to run through the child nodes of the "Homepage" node i dont get the level 1 node (Homepage) with the above example.
    If i leave the level at 1 i don't get the child nodes at all.
    Any advice here?
    Dec 10, 2010 @ 09:50
    Rich Green
    Hi Martin,
    For your version, set the level to 2 and try this code
    <li>
        <a href="/">
            </xsl:if>
            <xsl:value-of select="$currentPage/ancestor-or-self::root/node/@nodeName"/>
        </a>
    </li>
    Rich
    Dec 10, 2010 @ 22:13
    MartinB
    Hi Rich
    Oh, can do!
    I'll get back to you on that one, thanks :-)
    Dec 13, 2010 @ 09:04
    MartinB
    Hi Rich
    No go, unfortunately. If the level i set to "2", i get the children of the frontpage node, but not the Frontapage node itself.
    Dec 13, 2010 @ 09:08
    MartinB
    Hmm it seems that i'm not using the same XSLT anymore, can't remember when i made the switch :/
    <xsl:stylesheet
    version="1.0"
    <xsl:variable name="level" select="1"/>
    <ul id="menu">
    <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
    <li>
    <xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id">
    <xsl:attribute name="class">selected</xsl:attribute>
    </xsl:if>
    </a>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:template>
    </xsl:stylesheet>
  • Thijs Kuipers 43 posts 66 karma points
    Dec 13, 2010 @ 14:07
    Thijs Kuipers
    Try the following XPath to select all document nodes under root (with umbracoNaviHide is false):
    $currentPage/ancestor::root/*[@isDoc and string(umbracoNaviHide) != '1']
    This will:
    • Go to the ancestor called root (which is aptly called 'root' and happens to be the root of the Umbraco XML file)
    • Select all direct child nodes of any type (hence the *) that have the property 'isDoc' and do not have a child node called 'umbracoNaviHide' that contains the string value '1'.
    You cannot access the root node using [@level = $level] because it has no property called 'level'. That is why your first XPath $currentPage/ancestor-or-self::*[@level = 1]/../*[@isDoc] did work.
    • Go to the ancestor (or self) on level 1
    • Go to the parent (.. means parent) which happens to be the 'root'
    • Select all nodes with property 'isDoc'
    Dec 13, 2010 @ 20:11
    MartinB
    Hi Thjis
    Cool, i'll give it a go tomorrow!
    Thanks alot for your effort, much appreciated.
