  • MartinB 411 posts 512 karma points
    Dec 07, 2010 @ 19:14
    MartinB
    Level 0 Navigation (Top level nodes)
    Hi there
    Been searching the forums the last hour looking for an answer to how i get my level 0 (root) nodes liste with xslt for a toplevel navigation menu in the old schema.
    Structure looks like this example:
    - Domain 1
       - Home
       - About
         - Vision
    - Domain 2
       - Home
       - About
         - Vision
    - Domain 3
       - Home
       - About
         - Vision
    I started using the Prototype Navigation xslt, but when i set level=1 i get the nodes below Domain 1. If i set it to 0 i get nothing.
    XSLT:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <!-- Input the documenttype you want here -->
    <!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
    <!-- Use div elements around this macro combined with css -->
    <!-- for styling the navigation -->
    <xsl:variable name="level" select="2"/>
    <xsl:template match="/">
    <!-- The fun starts here -->
    <ul>
    <xsl:for-each select="$currentPage/ancestor-or-self::node [@level=$level]/node [string(data [@alias='umbracoNaviHide']) != '1']">
    <li>
    <xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id">
    <!-- we're under the item - you can do your own styling here -->
    <xsl:attribute name="style">font-weight: bold;</xsl:attribute>
    </xsl:if>
    </a>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:template>
    </xsl:stylesheet>
    Dec 07, 2010 @ 19:28
    MartinB
    Someone please delete this double post.
