  • Sajid Riaz 142 posts 165 karma points
    Dec 12, 2010 @ 16:01
    Sajid Riaz
    setting div id using xslt
    Hi ,
    I'm trying to set the id of a div as follows
     <div id=<umbraco:Macro Alias="SetContentID" runat="server"></umbraco:Macro>>
    this should render as follows <div id="default">
    but I dont know how to get the double quotes
    thanks
  • Sebastian Dammark 583 posts 1407 karma points
    Dec 12, 2010 @ 16:13
    Sebastian Dammark
    <div>
    <xsl:attribute name="id">
    <umbraco:Macro Alias="SetContentID" runat="server" />
    </xsl:attribute>
    Dec 12, 2010 @ 16:43
    Kim Andersen
    Hi Sajid
    If you want to create the div-element in your template, and then use a macro to insert the id attribute, you should be able to do it like this:
    In your template:
    <div <umbraco:Macro Alias="SetContentID" runat="server"></umbraco:Macro>>
    Then in your SetContentID xslt-file you should return something like this:
    id="default"
    You could create some different scenarios in your xslt-file using eg. a <xsl:choose> to determine what the id should be. Something like this:
    <xsl:choose>
    <xsl:when test="something here">id="alternativeID"</xsl:when>
    <xsl:otherwise>id="default"</xsl:otherwise>
    </xsl:choose>
    /Kim A
    Dec 12, 2010 @ 17:04
    Sajid Riaz
     Thanks Guys,
    Kim your method works good.
    heres my xslt:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
    <xsl:template match="/">
      <xsl:value-of select="$currentPage/backgroundImageID"/>
    </xsl:template>
    </xsl:stylesheet>
    here's how i used in html:
    <div id="<umbraco:Macro Alias='SetContentID' runat='server'></umbraco:Macro>">
    I set backgroundImageID the on the doc type.
    many thanks guys
    >sajid
    Dec 12, 2010 @ 17:53
    Kim Andersen
    Good to hear that you got i solved Sajid.
    But if your only want to output a textstring from the backoffice on the current page, you don't have to go through all the work of creating a XSLT-file/macro first. Then you can just do like this:
    <div id="<umbraco:Item field='backgroundImageID' runat='server'></umbraco:Item>">
    /Kim A
