Syntax for getting and using a document type property in 4.5 XML Schema
Hi everyone, new to Umbraco + Forum + XSLT ! Loving it so far.
I am a bit stuck with trying to achieve the following:
I have a document type where a user can, in the Content area, use a custom datatype (radio buttons) to select either 'valueA' or 'valueB' or 'valueC'.
In a XSLT file I would like to store a reference to the property name and then test its value to alter html output. For example:
$myProperty = Document Type Property Name
and later on in the code:
If $myProperty = 'valueA' then output this html, else if $myProperty = 'valueB' then output this html etc...
Please could someone help with sample syntax - I have seen the example in the Documentation about getting a document type property using the new XML Schema but found it too confusing.
I think there is another datatype that is called something like "Dropdown (publish values)", which will save the text instead of the id to the property field.
Something like this?
<xsl:variable name="myProperty" select="$currentPage/MyPropertyAlias"/> <xsl:choose> <xsl:when test="$myProperty = 'ValuaA'"> <h1>Value was A</h1> </xsl:when> <xsl:when test="$myProperty = 'ValuaB'"> <h1>Value was B</h1> </xsl:when> <xsl:otherwise> <h1>Value was something else</h1> </xsl:otherwise> </xsl:choose>Yes just like that, thankyou Morten!
I think I am missing just one thing. My Datatype settings look like this
Text Value
ValueA 5
ValueB 6
Using your code, $myProperty = '5' displays "Value was A"
but $myProperty = 'ValueA' displays "Value was something else".
Is there a setting I can change under the Datatype so your code matches the text instead of the number?
James
I think this would do that:
<xsl:variable name="myProperty" select="umbraco.library:GetPreValueAsString($currentPage/MyPropertyAlias)"/> <xsl:choose> <xsl:when test="$myProperty = 'ValueA'"> <h1>Value was A</h1> </xsl:when> <xsl:when test="$myProperty = 'ValueB'"> <h1>Value was B</h1> </xsl:when> <xsl:otherwise> <h1>Value was something else</h1> </xsl:otherwise> </xsl:choose>Haven't tested it, but try it out.
I tried it but no luck. I will keep trying things out :)
Thanks for making the main syntax clear, very much appreciated
Yes, following your advice I changed the datatype to 'Dropdown List' and now it matches the text!
