  • Anders Aleborg 35 posts 67 karma points
    Dec 29, 2010 @ 17:43
    Anders Aleborg
    Problem with RunawayTopNavigation.xslt
    I'm using the RunawayTopNavigation.xslt with some modifications but it doesn't display the main node.
    My structure is like this:
    - Start (frontpage)
    - - Page 1
    - - Page 2
    - - Page 3
    Currently it only displays
    Page 1  |  Page 2  |  Page 3
    But I want it to display the main node as well
    Start  |  Page 1  |  Page 2  |  Page 3
    From my xslt:
                <xsl:for-each select="$currentPage/ancestor-or-self::* [@level = $level]/* [string(umbracoNaviHide) != '1' and @isDoc]">
                  <xsl:choose>
          <!-- Check if the page is an external link -->
                    <xsl:when test="externalLink = 1">
                      <li id="mnu_{@nodeTypeAlias}">
                        <a href="{link}" title="{@nodeName}">
                        </a>
                      </li>
                    </xsl:when>
                    <xsl:otherwise>
                      <xsl:choose>
              <!-- It's not external link so let's check if it's the active page and set a new class -->
                        <xsl:when test="$currentPage/ancestor-or-self::root//@id = @id">
                            <a href="{umbraco.library:NiceUrl(@id)}" title="{@nodeName}" class="active">
                            </a>
                          </li>
                        </xsl:when>
                        <xsl:otherwise>
                  <!-- Not an external link or the active page, display it normal -->
                            <a href="{umbraco.library:NiceUrl(@id)}" title="{@nodeName}">
                            </a>
                          </li>
                        </xsl:otherwise>
                      </xsl:choose>
                    </xsl:otherwise>
                  </xsl:choose>
                </xsl:for-each>
    Another problem is that all menu items, except external get the class="active"
    Any ideas?
    Dec 29, 2010 @ 17:50
    Hi Anders
    Problem 1: It's because the XSLT will only give you those nodes under the root node, in this case your start page. I'm not sure how to make an elegant solution to it, but a pragmatic approach could be to simply just hardcode the link to the startpage outside of the for-each loop. I've done this on some occasions.
    Problem 2: Try altering this piece of code
    to this instead
    <xsl:when test="$currentPage/ancestor-or-self::*/@id = current()/@id">
    Hope this helps
    Dec 29, 2010 @ 17:52
    Kim Andersen
    Hi Anders
    To get the main node as well, you can insert this piece of code just before the for-each:
    <li>
    <a href="/">
    <xsl:if test="
    $currentPage/@level = '1'">
    <xsl:attribute name="class">active</xsl:attribute>
    </xsl:if>
    $currentPage/ancestor-or-self::* [@level = $level]/@nodeName" />
    </a>
    </li>
    /Kim A
    Dec 29, 2010 @ 18:29
    Anders Aleborg
    Thanks Kim and Jan, that did the trick!
    Dec 29, 2010 @ 20:05
    Anders Aleborg
    If I want to do the same thing in a submenu, so that the first node in the submenu is the parent node? How can I do that?
    <xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
    <xsl:choose>
    <xsl:when test="$currentPage/@id = @id">
      <li class="submenuactive">
        </a>
      </li>
    </xsl:when>
    <xsl:otherwise>
      <li>
        </a>
      </li>
    </xsl:otherwise>
    </xsl:choose>
    </xsl:for-each>
    Dec 29, 2010 @ 20:15
    Kim Andersen
    You can probably change your code to this:
    <xsl:variable name="subNode" select="$currentPage/ancestor-or-self::* [@level=$level]" />
    <li>
    <a href="umbraco.library:NiceUrl($subNode/@id)">
    $subNode/@nodeName" />
    </a>
    </li>
      <li>
    <xsl:if test="
    $currentPage/@id = ./@id">
    submenuactive</xsl:attribute>
    </xsl:if>
        </a>
      </li>
    </xsl:for-each>
    Then you'll also save some writing, because you don't have to use that xsl:choose, when the only difference is the class on the li-tag, when the node is active.
    /Kim A
    Dec 29, 2010 @ 22:32
    Anders Aleborg
    thanks, but this: {umbraco.library:NiceUrl($subNode/@id)}
    Gives me: System.OverflowException: Value was either too large or too small for an Int32.
    Dec 29, 2010 @ 22:34
    Hi Anders
    That's because the XSLT does not know the value before runtime. So in this case you can safely check the "Skip error testing" checkbox when you save your XSLT.
