  • Ralph van Vugt 57 posts 101 karma points
    Jan 03, 2011 @ 09:12
    Ralph van Vugt
    Sort order problem
    I have a small problem with sorting prices ascending.
    Product 1 costs € 15,00, product 2 costs 9,00 and product 3 costs 7,50. When sorting using xslt:sort this is the result:
    - product 1
    - product 3
    - product 2
    That is because 1 comes before 7 and 9
    But in price, the order must be product 3 - product 2 - product 1.
    How can I let XSLT know it is a price instead of a number?
    Jan 03, 2011 @ 09:17
    Hi Ralph
    What value do you have in your sort order? Does'nt it help to just set sort="ascending" ?
    You can see the different options here: http://w3schools.com/xsl/el_sort.asp
    Jan 03, 2011 @ 09:33
    Ralph van Vugt
    Hi Jan,
    Unfortunately not. I've set the order to ascending, but it doesn't make a difference.
    If I format the prices with two digits for the comma (such as 07,50) it sorts right, but when losing the '0' it sorts wrong.
    Ralph
    Jan 03, 2011 @ 09:34
    Ralph van Vugt
    Jan,
    Maybe I've found the answer here: http://www.w3schools.com/Xsl/func_formatnumber.asp
    I'll try.
    Thanks!
    Ralph
    Jan 03, 2011 @ 10:07
    Hi Ralph
    Ah yes I should had thought of that option myself. It makes sense I it really should solve your problem.
    Jan 03, 2011 @ 10:18
    Ralph van Vugt
    Hi Jan,
    Found it. Check http://efreedom.com/Question/1-3758978/XSLT-Format-Number-Comma
    <xsl:decimal-format name="nl" decimal-separator="," grouping-separator="."/>
    <xsl:sort select="format-number(translate($price, ',','.'), '00,00', 'nl')" order="ascending" />
