You should only add the exception to the possibleNode variable, something like this should do the trick:
<xsl:variable name="possibleNodes" select="$items/descendant-or-self::*[ @isDoc and string(umbracoNaviHide) != '1' and count(attribute::id)=1 and (umbraco.library:IsProtected(@id, @path) = false() or umbraco.library:HasAccess(@id, @path) = true()) and local-name() != 'TextImageData' ]"/>
Search module - Problem with ignoring particular nodes
Thanks!
