I'm having a bit of trouble getting the values from a nodeset. To me it would seem obvious and straight forward, but I simply can't get it to show any output.
Basically what I want is to get all documents of document type 'Kommentar' and 'Annonce' and display some data from them. Since I have loops inside a variable it seems I have to use the msxml:node-set() method to make a node set out of my variable which is, of course, all good!
When I try to <xsl:copy-of select="$nodeSet" /> I get the following XML:
<kommentar id="1205" parentid="1138" level="4" writerid="0" creatorid="0" nodetype="1101" template="1102" sortorder="4" createdate="2011-01-06T18:21:37" updatedate="2011-01-06T18:21:37" nodename="06-01-2011_Bo Mortensen" urlname="06-01-2011_bo-mortensen" writername="Administrator" creatorname="Administrator" path="-1,1053,1064,1138,1205" isdoc="">
<navn>Bo Mortensen</navn>
<email>myemail@mydomain.com</email>
<website>http://www.mysite.com</website>;
<kommentar>Dette er en test kommentar!</kommentar>
</kommentar>
How exactly do I get these data since current()/@id apperantly doesn't work?
Here's my XSLT for future reference if it's any good at all. As you can see, it's a rather complex task where I'm listing the recent frontend user activity:
<!-- The fun starts here --> <xsl:variable name="nodes"> <!-- GET ALL COMMENTS --> <xsl:for-each select="$currentPage/ancestor-or-self::*/*//Kommentar [@isDoc]"> <xsl:sort select="@sortOrder" data-type="number" order="descending" /> <xsl:if test="position() < 6"> <xsl:copy-of select="." /> </xsl:if> </xsl:for-each> <!-- GET ALL ADS --> <xsl:for-each select="$currentPage/ancestor-or-self::*//Annonce [@isDoc]"> <xsl:sort select="@sortOrder" data-type="number" order="descending" /> <xsl:if test="position() < 6"> <xsl:copy-of select="." /> </xsl:if> </xsl:for-each> </xsl:variable> <xsl:variable name="nodeSet" select="msxml:node-set($nodes)" />
<xsl:for-each select="$nodeSet/*"> <xsl:variable name="parentNode" select="umbraco.library:GetXmlNodeById(current()/@parentID)" /> <xsl:variable name="parentNodeOfParentNode" select="umbraco.library:GetXmlNodeById($parentNode/@parentID)" /> <!-- ACTIVITY DATE --> <span class="activityDate"><xsl:value-of select="umbraco.library:FormatDateTime(current()/@createDate, 'dd-MM-yyyy HH:mm')" /> </span> <!-- IF CURRENT NODE IS A COMMENT --> <xsl:if test="local-name($parentNode) = 'KommentarDato'"> <xsl:value-of select="current()//navn" /> <!-- IF CURRENT IS IN GUESTBOOK --> <xsl:if test="$parentNodeOfParentNode/@template = '1137'"> skrev i <a href="{umbraco.library:NiceUrl($parentNodeOfParentNode/@id)}">gæstebogen</a> </xsl:if>
<!-- IF CURRENT IS A NEWS COMMENT --> <xsl:if test="local-name($parentNodeOfParentNode) = 'Nyhed'"> en kommentar til nyheden <a href="{umbraco.library:NiceUrl($parentNodeOfParentNode/@id)}"><xsl:value-of select="$parentNodeOfParentNode/@nodeName" /></a> </xsl:if> <!-- IF CURRENT IS A BUY-SECTION COMMENT --> <xsl:if test="local-name(umbraco.library:GetXmlNodeById($parentNodeOfParentNode/@parentID)) = 'Kb'"> en kommentar til annoncen <a href="{umbraco.library:NiceUrl(current()/@id)}"><xsl:value-of select="$parentNodeOfParentNode/@nodeName" /></a> i købssektionen </xsl:if> <!-- IF CURRENT IS A SALE-SECTION COMMENT --> <xsl:if test="local-name(umbraco.library:GetXmlNodeById($parentNodeOfParentNode/@parentID)) = 'Salg'"> en kommentar til annoncen <a href="{umbraco.library:NiceUrl($parentNodeOfParentNode/@id)}"><xsl:value-of select="$parentNodeOfParentNode/@nodeName" /></a> i salgssektionen </xsl:if> </xsl:if> <!-- IF CURRENT IS A 'BUY' NODE --> <xsl:if test="local-name($parentNode) = 'Kb'"> <strong> Køb: </strong> <xsl:value-of select="current()/navn" /> oprettede annoncen <strong><xsl:value-of select="current()/@nodeName" /></strong> </xsl:if> <!-- IF CURRENT IS A 'SALE' NODE --> <xsl:if test="local-name($parentNode) = 'Salg'"> <strong> Salg: </strong> <xsl:value-of select="current()/navn" /> oprettede annoncen <strong><xsl:value-of select="current()/@nodeName" /></strong> </xsl:if> <br /><br /> </xsl:for-each>
This XLST will be placed on the Master template which means it's being called on every postback! Will this cause a huge overhead? If so, is there a way to sort of.. "cache" the results or something like that?
Problems getting values from nodeset
Hello all,
My XSLT (i'll try to explain):
<kommentar id="1205" parentid="1138" level="4" writerid="0" creatorid="0" nodetype="1101" template="1102" sortorder="4" createdate="2011-01-06T18:21:37" updatedate="2011-01-06T18:21:37" nodename="06-01-2011_Bo Mortensen" urlname="06-01-2011_bo-mortensen" writername="Administrator" creatorname="Administrator" path="-1,1053,1064,1138,1205" isdoc=""> <navn>Bo Mortensen</navn> <email>myemail@mydomain.com</email> <website>http://www.mysite.com</website>; <kommentar>Dette er en test kommentar!</kommentar> </kommentar>How exactly do I get these data since current()/@id apperantly doesn't work?
Thanks in advance! :-)
/ Bo
Solved it! :)
Thanks again! :)
