  • Peter Svensson 2 posts 22 karma points
    Jan 14, 2011 @ 13:17
    Peter Svensson
    Help with XPATH needed
    Hi All,
    I'm in need for some help with a xpath-expression and I'm hoping that someone could point me in the right direction. I've attached the following screenshot:
    What I'm looking for is the xpath to search in any of the "stu---"nodes (DocumentType: X) when located in the "search"-node. I'm on version 4.5.2.
    Thanks in advance! // Peter
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Jan 14, 2011 @ 14:03
    Matt Brailsford
    Hey Peter,
    If you "stu---" nodes are the only nodes to user DocumentType X, you could do something like this?
    $currentPage/ancestor::root//*[name() = 'X' and @isDoc]
    Which basically says, from the current page, travel to the root node, then find any decendants (at any level) which are documents, and which use the X document type.
    Matt
    Jan 14, 2011 @ 14:48
    Peter Svensson
    Thanks! Works like a charm / Peter
    Jan 14, 2011 @ 14:50
    Matt Brailsford
    Excellent.
    Matt
