Hi All,
I'm using 4.0.3 on a client site and trying to pass a parameter through a macro into the XSLT
This is my code:
<xsl:param name="currentPage"/><xsl:param name="imageFolder" select="/macro/selectedfolder" /><xsl:template match="/"> <xsl:copy-of select="$imageFolder" /> <xsl:if test="$imageFolder != ''"> <xsl:for-each select="umbraco.library:GetMedia($imageFolder,'false')/node"> <xsl:element name="img"> <xsl:attribute name="alt"> <xsl:value-of select="@nodeName"/> </xsl:attribute> <xsl:attribute name="src"> <xsl:value-of select="./data [@alias='umbracoFile']" /> </xsl:attribute> </xsl:element> </xsl:for-each> </xsl:if></xsl:template>
But nothing is coming through, the parameter type is mediaCurrent()
Tom
Try look at macro parameters. Put this before your code, any you can see parameter values
<textarea> <xsl:copy-of select="/macro" /></textarea>
Petr
Hi Petr,
Thats returns <macro />.
Go to macro definition and add macro parameters on parameters tab.
If you have set it correctly, try post html which call macro and your version of umbraco.
Ok, I've added another parameter contentPicker and that is returning a value but the mediaCurrent is always getting lost when getting published.
Right this is wierd, I've removed it and added it again and now it works!!
CONFUSED!!
Thanks for the hint re the textarea
I'm glad it help. You can mark one of my answers like solution :-)
Macro parameters not passing through
Hi All,
This is my code:
Tom
Petr
Hi Petr,
Tom
CONFUSED!!
Tom
