  • jing.ling 29 posts 20 karma points
    Mar 06, 2009 @ 03:26
    jing.ling
    How to select all nodes with particular document type? (problem solved. thx)
    Hi. I am currently building a website with umbraco. The structure is like this:
    -- Home
    -- About us
    -- Resources
    -----Latest News
    ---------News 1
    ---------News 2
    ---------News 3
    ---------News 4
    -- Contact us
    (etc)
    For the document type:
    (1) Home template
    --- has property: NumberofItemsToDisplay ...
    (2) LatestNewsPage template
    --- has property: 'umbracoNaviHide' ...
    (3) News template
    --- has property: 'umbracoNaviHide', 'NewsHeader'...
    What I want to do is to list latest 3 news on the home page. So I wrote a XSLT file as follow in the home page template:
    [code]
    Mar 06, 2009 @ 08:32
    Dirk De Grave
    [code]
    Mar 08, 2009 @ 22:50
    jing.ling
    Thanks Dirk. You code works perfect. But is there any way to make code more generic? like, dymatically search all nodes and find the "latest News" page?
    thanks
    Mar 09, 2009 @ 09:55
    Dirk De Grave
    sure that is possible... use umbraco.library.GetXmlAll() for this purpose.
    [code][/code]
    Hope this helps.
    Regards,
    /Dirk
    Mar 10, 2009 @ 04:45
    jing.ling
    Hi Dirk
    Thanks for help. I tried the code, but it does not work.
    [code]
    [/code]
    can you help me to fix it?
    Mar 10, 2009 @ 08:59
    Dirk De Grave
    try using
    [code][/code]
    or
    [code][/code]
    Regards,
    /Dirk
    Mar 10, 2009 @ 20:06
    jing.ling
    Thanks Dirk. both your solutions work for me. By the way, what's the differece between "/descendant::node" and "//node"?
    Thanks again.
    Mar 10, 2009 @ 20:38
    Dirk De Grave
    No difference, the latter is just a short hand notation of the first.
    Here's a book on the xpath axis and their shortcuts: http://umbraco.org/documentation/books/xslt-basics/xpath-axes-and-their-shortcuts
    Regards,
    /Dirk
    Mar 10, 2009 @ 23:17
    jing.ling
    Thanks for your help Dirk.
  • Paul McGinnity 2 posts 21 karma points
    Jul 29, 2009 @ 16:28
    Paul McGinnity
    I was just looking at this post in the hope that it would solve a simillar problem I've been having. But I can only see the post text, not the actual code snippets that should be in the grey boxes. Does anyone know why this is?
    Paul.
    Jul 29, 2009 @ 16:29
    Jul 29, 2009 @ 16:37
    Paul McGinnity
    Thanks Sebastiaan, my brain is somewhat dead this afternoon. I've just been round the office trying the page on different systems.
    Paul.
