  • Tom Cowling 144 posts 343 karma points
    Jan 18, 2011 @ 13:36
    Tom Cowling
    Current url to variable problem (should be simple!)
    I'm sure this should be REALLY easy, but for some reason it just isn't working. I've scoured the forums and can't seem to find an answer to this. Basically all I want to do is pass the current page's url to a variable so I can use it later on.I can get it to print out the site's domain if I take out the following line
    <xsl:value-of select="umbraco.library:NiceUrl(@id)" />
    but as soon as I try to get the current node, it throws a wobbly and tells me there is a problem with my xslt (System.OverflowException: Value was either too large or too small for an Int32.)
    Below is my code:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
      <xsl:variable name="pageURL">
        <xsl:text>http://</xsl:text>
      <xsl:value-of select="umbraco.library:RequestServerVariables('HTTP_HOST')" /><xsl:value-of select="umbraco.library:RequestServerVariables('HTTP_HOST')" /><xsl:value-of select="umbraco.library:NiceUrl(@id)" />
      </xsl:variable>
    <xsl:template match="/">
    <!-- start writing XSLT -->
      <p>Page url is:<br /><xsl:value-of select="$pageURL"/></p>
    </xsl:template>
    </xsl:stylesheet>
    Any light that can be shed on this would be much appreciated!
    Thanks a lot,
    Tom
    Jan 18, 2011 @ 13:41
    Tom Cowling
    Sorry this is the code used:
    <xsl:stylesheet
      version="1.0"
    Exslt.ExsltSets "
      </xsl:variable>
    </xsl:template>
    </xsl:stylesheet>
    For some reason, the forum won't let me edit the original...
    Jan 18, 2011 @ 13:45
    Dirk De Grave
    Don't you have to use $currentPage/@id instead of only @id?
    /Dirk
    Jan 18, 2011 @ 13:46
    Tom Cowling
    Spot on!
    Nice one. :D
  • Adam 7 posts 27 karma points
    Jan 19, 2011 @ 07:21
    Adam
    I'd like to take this one step further and insert the value of the url into an alias I've got called "myURL".
    I'm working on a "Send to a friend" form using Doc2Form and loading it within an iframe, so I need to feed the form the URL via the myURL alias.
    This should be simple, but it's stumping me for now.
    Any help is appreciated.
    Cheers
    Adam
    Jan 19, 2011 @ 10:35
    Tom Cowling
    Funnily enough, that's exactly what I wanted it for! :)
    Code below:
    <xsl:stylesheet
      version="1.0"
        <xsl:value-of select="umbraco.library:NiceUrl($currentPage/@id )" />
      </xsl:variable>
      <xsl:variable name="pageTitle">
        <xsl:value-of select="$currentPage/data[@alias='Heading']"/>
      </xsl:variable>
    <p><strong>Bookmark &amp; Share this article with:</strong></p>
    <a title="Share this article on Twitter" target="_blank" href="http://twitter.com/home?status={$pageURL}">Twitter</a>
    </xsl:template>
    </xsl:stylesheet>
    Good luck!
    Tom
    Jan 31, 2011 @ 00:16
    Adam
    Hi Tom,
    Thanks heaps for your help with my problem, and sorry it's taken me a while to get back about this.
    I can see how to store a value into a variable, but not how to send that value to a field (or alias) in another page via Umbraco. I'm no .net/c# wiz so perhaps I'm missing something obvious?
    In the end I leveraged on jQuery for the final solution. The user needs javaScript to view videos anyway, so to send the current video to a friend, I copied the url to the iframe form that Doc2Form generates for the user to send off, and it works well.
    Cheers
    Adam
    Code below if you're curious.
    $("#email-friend").click(function () {
        //Grab the current Page URL
        var pageURL = document.location.href;
        //Locate the field (#ctl00_ctl00_ContentPlaceHolderDefault_Doc2Form_1_myURL) in the iframe (#email-friend-fr) to store the Page URL
        var sendURL = $("#email-friend-fr").contents().find("#ctl00_ctl00_ContentPlaceHolderDefault_Doc2Form_1_myURL");
        //Inject the Page URL into the hidden URL field inside the iframe form.
        $(sendURL).val(pageURL);
        return false;
