I'm skipping all the jQuery stuff above - guessing you want the HTML output showed at first?
Here's a no-frills, walk-in-the-park, simple XSLT template that does the trick, utilizing the built-in traversal techniques (apply-templates) and clean, short templates for the differing output versions of links:
The anchors I left for you to fill in :-) - just use <a href="{umb:NiceUrl(@id)}">
Are you not getting the correct HTML or does the jQuery stuff just not work? (The jQuery snippet seem to target some elements that are not in the HTML you supplied - e.g. the id "sub-link-bar" isn't provided anywhere, which could be a reason)
How are you Content nodes structured? I was assuming something like:
Content
- Home
- Item 1
- Item 2
- About
- Item 1
- Item 2
Setting a class attribute to a ul li within XSLT
I am trying to mimic a jquery nav applet I have used before within a Umbraco site using XSLT. I am nearly there but its not working as expected.
The heirarchy I am trying to create is this:
<ul id="main-nav">
<li><a class="main-link" href="">Home</a>
<ul class="sub-links">
<li><a href="" title=""><img src="Images/arrow.png" />Item1</a> </li>
</ul>
</li>
<li><a class="main-link" href="">About</a>
</ul>
</li>
<li><a class="close" title="Click to Collapse" href="#">X</a></li>
</ul>
Note the classes for the top ul "Main-nav", the li "main-link" and the second ul "sub-links"
I have a bit of Jquery that opens the slide panel (sub-link-bar) and shows the subordinates
$(document).ready(function(){
$("#main-nav li a.main-link").hover(function(){
$("#main-nav li a.close").fadeIn();
$("#main-nav li a.main-link").removeClass("active");
$(this).addClass("active");
$("#sub-link-bar").animate({
height: "40px"
$(".sub-links").hide();
$(this).siblings(".sub-links").fadeIn();
}, function(){});
$("#main-nav li a.close").hover(function(){
$(".sub-links").fadeOut();
height: "3px"
$("#main-nav li a.close").fadeOut();
</script>
HOWEVER!
The bit of XSLT i am using doesn't let me style the second ul as it calculated:
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:PS.XSLTsearch="urn:PS.XSLTsearch"
exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets PS.XSLTsearch ">
<!-- update this variable on how deep your site map should be -->
<xsl:variable name="maxLevelForSitemap" select="4"/>
<xsl:template match="/">
<div id="sitemap">
<xsl:call-template name="drawNodes">
<xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@isDoc and @level=1]"/>
</xsl:call-template>
</xsl:template>
<xsl:template name="drawNodes">
<xsl:param name="parent"/>
<xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)">
<ul id="main-nav">
<xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1' and @level <= $maxLevelForSitemap]">
<li><a class="main-link" href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a>
<xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1' and @level <= $maxLevelForSitemap]) > 0">
<xsl:call-template name="drawNodes"><xsl:with-param name="parent" select="."/></xsl:call-template>
</xsl:if>
</li>
</xsl:for-each>
</ul>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
I appreciate that this may be rudimentary XSLT but I am struggling with it.
I did modify the Jquery to look at the li ul nodes and this sort of works:
height: "100px"
$("li ul").hide();
$(this).siblings("li ul").fadeIn();
}, function(){});
$("li ul").fadeOut();
height: "3px"
</script>
However the on:hover does not persist allowing me to select the subordinates.
In a bit of a pickle.
Can anyone help?
Hi Streety,
<?xml version="1.0" encoding="utf-8" ?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:umb="urn:umbraco.library" exclude-result-prefixes="umb" > <xsl:output method="xml" indent="yes" omit-xml-declaration="yes" /> <xsl:param name="currentPage" /> <!-- Assuming the site root is at level 1, otherwise modify --> <xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::*[@level = 1]" /> <xsl:template match="/"> <ul id="main-nav"> <xsl:apply-templates select="$siteRoot/*[@isDoc][not(umbracoNaviHide = 1)]" /> </ul> </xsl:template> <!-- Template for top level nodes --> <xsl:template match="*[@isDoc]"> <li> <a class="main-link" href=""><xsl:value-of select="@nodeName" /></a> <xsl:if test="*[@isDoc][not(umbracoNaviHide = 1)]"> <ul class="sub-links"> <xsl:apply-templates select="*[@isDoc][not(umbracoNaviHide = 1)]" mode="sub" /> </ul> </xsl:if> </li> </xsl:template> <!-- Sub levels --> <xsl:template match="*[@isDoc]" mode="sub"> <li> <a href=""> <img src="/Images/arrow.png" /> <xsl:value-of select="@nodeName" /> </a> </li> </xsl:template> </xsl:stylesheet>/Chriztian
Hi Chriztian,
Thank you for your efforts. Unfortunately I get the top level links shown and not the sub links.
Also the anchor hrefs don't seem to be wired up. Have I missed a stage?
Hi Streety,
/Chriztian
