  • Phil Crowe 192 posts 256 karma points
    Jan 20, 2011 @ 14:49
    Phil Crowe
    using c# random method really slow in xslt
    Im having problems trying to select a radom node from a list of nodes in my xslt:
    <!DOCTYPE xsl:stylesheet [
      <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
    version="1.0"
    exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets myfunctionlib"
      xmlns:myfunctionlib="urn:myfunctionlib"
      xmlns:PS.Helpers="urn:PS.Helpers"
    <msxml:script implements-prefix="myfunctionlib" language="C#" >
    <![CDATA[
    Random r = new Random();
    public int RandomPos(int max) {
        return r.Next(max);
    </msxml:script>
    <xsl:variable name="source" select="/macro/source"/>
    <xsl:variable name="maxresults" select="/macro/MaxResults" />
    <xsl:template match="/">
      <img src="/images/my-collection/black-up.jpg" id="mycollup" />
      <ul>
        <xsl:variable name="selectsourcenode" select="umbraco.library:GetXmlNodeById($source)" />
        <xsl:call-template name="displayrow">
        <xsl:with-param name="getNode" select="$selectsourcenode" />
        <xsl:with-param name="counter" select="1" />
        <xsl:with-param name="maxrows" select="count($selectsourcenode//TextImageData)" />
        </xsl:call-template>
      </ul>
      <img src="/images/my-collection/black-down.jpg" id="mycolldown" />
    </xsl:template>
        <xsl:template name="displayrow">
          <xsl:param name="counter" />
          <xsl:param name="maxrows" />
     <xsl:param name="getNode" />
          <xsl:variable name="smallcase" select="'abcdefghijklmnopqrstuvwxyz'" />
          <xsl:variable name="uppercase" select="'ABCDEFGHIJKLMNOPQRSTUVWXYZ'" />
          <xsl:variable name="ranNodeNum" select="myfunctionlib:RandomPos($maxrows)" />
            <xsl:variable name="nonrandomnode" select="$getNode//TextImageData[position()=$ranNodeNum]"/>
    <xsl:variable name="randomnode" select="$nonrandomnode [not(@id=preceding-sibling::node/@id)]"/>
    <xsl:value-of select="$maxrows"/>
          <xsl:choose>
              <xsl:when test="$randomnode/member != ''">
                <li class="licomment">
                <xsl:variable name="mxml" select="umbraco.library:GetMember($randomnode/member)" />
                <div class="myCollectionLatest" id="mycollectioncomment{$counter}">
                  <div style="float:left;">
                    <div class="colltoppic">
                      <a href="/my-collection.aspx?memberId={$mxml/*/@id}">
                <img src="{$mxml/node/profilePicture}" width="74" height="74" onerror="ImgError(this);" />
                      </a>
                    <xsl:choose>
                      <xsl:when test="string-length($randomnode/image) &gt; 1">
                        <div class="commentimage ie6commentimageifx" style="clear:both;">
                          <img src="{$randomnode/image}"  width="74" height="74" />
                      </xsl:when>
                      <xsl:otherwise>
                          <img src="/images/my-collection/c2k-tip-placeholder.jpg"  width="74" height="74" />
                      </xsl:otherwise>
                    </xsl:choose>
                    <div style="float:left; position:absolute; margin-left:83px; margin-top:-84px; width:160px;" class="mycolllatestlinks">
                        <b>
                          <xsl:variable name="parent" select="$randomnode/@parentID">
                            </xsl:variable>
                          <!--  <xsl:variable name="granparent" select="$randomnode/../../@id" /> -->
    <!--<xsl:choose>
    this is the check to see if a gran-parent exsists, currently some nodes reference an incorrect parent id-->
    <!-- <xsl:when test="contains($granparent/@path, '-1')">
    <a href="/my-collection.aspx?memberId={$mxml/*/@id}" class="usernamelinkdiv">
    <xsl:value-of select="translate($mxml/node/screenName, $smallcase, $uppercase)"/>
    </a> SAID
    </xsl:when>
    <xsl:otherwise> -->
    <xsl:choose>
    <xsl:when test="string-length($randomnode/../../@nodeName) &gt; 0">
    </a> SAID ABOUT
    <span class="pinkTxt">
    <br />
    <xsl:choose>
    <xsl:when test="name($randomnode/../../.) = 'ProductCategory'">
    <a href="{umbraco.library:NiceUrl($randomnode/../../@id)}?categoryId=1">
    <xsl:value-of select="translate($randomnode/../../@nodeName, $smallcase, $uppercase)"/>
    </a>
    </xsl:when>
    <xsl:when test="name($randomnode/../../.) = 'ProductSubCategory'">
    <a href="{umbraco.library:NiceUrl($randomnode/../../@id)}?searchingForProduct=1">
    </a>
    </xsl:when>
    <xsl:otherwise>
    <a href="{umbraco.library:NiceUrl($randomnode/../../@id)}">
    </a>
    </xsl:otherwise>
    </xsl:choose>
    </span>
    </xsl:when>
    <xsl:otherwise>
    </a> SAID
    </xsl:otherwise>
    </xsl:choose>
    <!--add this because some comments didnt seem to have a product against them-->
    <!-- </xsl:otherwise>
    </xsl:choose>-->
                        </b>
                      <p>
                      <xsl:value-of select="substring(umbraco.library:StripHtml($randomnode/text),1,120)" />...
                    </p>
                    <div class="randomCommentsSeeMore">
                          See more <img src="/images/navControls/more-arrow.jpg" alt="see more" />
                        </a>
                    </span>
              </li>
                <xsl:if test="$counter &lt; $maxresults">
     <xsl:with-param name="getNode" select="$getNode" />
                    <xsl:with-param name="counter" select="$counter + 1" />
                    <xsl:with-param name="maxrows" select="$maxrows" />
                </xsl:if>
           </xsl:when>
          <xsl:when test="$randomnode/member = ''">
                <xsl:with-param name="counter" select="$counter" />
            </xsl:if>
          </xsl:when>
          <xsl:otherwise>
            </xsl:if>
          </xsl:otherwise>
          </xsl:choose>
        </xsl:template>
    </xsl:stylesheet>
    im trying to get a scrollable list of random items. maxrows currently equals 541 rows and the maxresults is 10. if i change the randomPos method at the top of the xslt to return a low number like
    return r.Next(12) + 1; instead of the maxrow parameter its alot quicker, i dont get it though surely this is just going to just spit out 10 random numbers, there shouldnt be any calculations that would slow it down. any ideas?
    Jan 20, 2011 @ 15:14
    Hi Phil
    I must admit that I have not looked your code through very thoroughly since the formatting is not very good (I blame the RTE for this - not you :)).
    However it seems like you're writing some C# of your own, correct?
    I think that instead you should perhaps try and follow this guide to get random nodes: http://our.umbraco.org/wiki/reference/xslt/snippets/getting-a-series-of-unique-random-numbers
    But it's not a good practive to use inline C# - So if you have the skills you will probably achieve better performance creating a XSLT extension to give you the randomness you need. However the guide I have linked you to works like a charm and I have not experienced any bad performance on those sites I've used it on so far.
    Hope this helps.
    Jan 20, 2011 @ 18:20
    Phil Crowe
    thanks jan, tried your suggestion but got the same result. problem seems to be this line:
    if i try and get a node with a position higher than 50 it all goes very slow, actually i havent yet been able to load a page with a node higher 50.
    Jan 20, 2011 @ 19:08
    Phil Crowe
    im getting even more confused now.
    <xsl:for-each select="$getNode//TextImageData[@isDoc and position() = 66]">
    node here
    </xsl:for-each>
    this shows me there is a node at position 66, but then
    <xsl:for-each select="$getNode//TextImageData[@isDoc and position() = 67]">
    node here
    </xsl:for-each>
    shows me nothing! like theres no node at this position or any position after. Any ideas????
    Jan 27, 2011 @ 15:31
    Phil Crowe
    i didnt get a solution out of this so thought i'd try and bring it back up. basically when reading the xml the 'for-each' gets 67 nodes down the list ok but once it gets to 68 nodes or further, it just gives up.
