I'm working on a site where the Body Text for a node sometimes can become very long and could use som paging. I'm looking for away to create paging for the Body Text property. Is this possible to do with XSLT? Any help would be very appriciated!
You might be able to use the code to spit out x words "per page",
Either way, an xslt extension would be the way I would approach the problem as I can't think of a way of doing it in XSLT without stripping out all the HTML. (HTML needs to be stripped out or well formed as otherwise you could get stuck in an open tag at the end of a page)
This allows you to output x characters of a string between position n and position n+i, so you could use it for paging. (e.g. 10,000 characters per page)
Paging long "Body Text" with XSLT?
Best regards,
Magnus
Hi Magnus,
I wrote an XSLT extension a while back to display the first n words of a blog post (with well formed HTML).
(Blog post on topic here: http://www.thecogworks.co.uk/blog/2011/1/21/n-word-preview-for-blog4umbraco)
If you don't need HTML in the body text, just use the umbraco library strip html method (http://our.umbraco.org/wiki/reference/umbracolibrary/striphtml) and then the XSLT sub string method; http://zvon.org/xxl/XSLTreference/Output/function_substring.html
Many Thanks,
Tom
