  • pat 124 posts 346 karma points
    Jan 31, 2011 @ 12:22
    pat
    how to create search for products like vehicles / home search
    I thought create search for products in website, suppose my products vehicles. If I create document type for product with propeties price, make, age, width , height, category .....
    so when adding product pages i can fill all these and publish, but when I need to create search like autotreader and other vehicle websites, how do I create this and navigate to a list of products on search criterias. If I do this with table for products record and my own aspx page this is not a question to ask , actually I am new to umbraco. so I have problem to build a shop in the website.
    please give your advise.
    I prefered to generate custom table and custom pages for shop if I can intergrate to the  umbraco site. any ideas???
  • Seth Niemuth 275 posts 397 karma points
    Jan 31, 2011 @ 13:21
    Seth Niemuth
    If you are looking to create a shop you may want to use commerce for umbraco: http://our.umbraco.org/projects/collaboration/commerce-for-umbraco or uCommerce: http://our.umbraco.org/projects/website-utilities/ucommerce. Or at least download and install and see how they have done things. I would use XSLT search in order to search your site if you are doing the products in doc types: http://our.umbraco.org/projects/website-utilities/xsltsearch. You can create custom sections and put usercontrols and ASPX pages into these custom sections, thus being able to save your products into a custom table and using custom pages.
  • jigar 170 posts 233 karma points
    Jan 31, 2011 @ 14:07
    jigar
    Hi Pathini Fernando,
    What you can do is the following.
    • You could careate custom table for you products and category.
    • Create user control to accept them and manage them.
    • Create search related user control that deals with search on these tables.
    • Intigrate the above in umbraco.
    Regards,
    Jigar
    Jan 31, 2011 @ 16:30
    pat
    Do I need to Visual studio to create user controls or can I use visual web developer 2008 express to develop usercontrols?
    then I cannot see any dll files???
    Jan 31, 2011 @ 18:06
    pat
    I would prefer create custom tables and usercontrols because i have more functional pages for the site I am going to develope using umbraco.
    Please anyone to tell me how can I add web user control created in visual web developer rather than visual studio? I hvae seen somewhere that we can copy dll to umbraco site.  but in visual web developer i cannot create dll files.
    please how to do this
  • Jonas Eriksson 930 posts 1825 karma points
    Jan 31, 2011 @ 19:53
    Jonas Eriksson
    Hi Pathini
    You can use CodeFile instead of CodeBehind in your Ascx file header and then just include the codebehind file. Or - dont use code behind at all:
    <%@ Control Language="C#" ClassName="WebUserControl" %>
    <script runat="server">
    </script>
    Feb 01, 2011 @ 12:32
    pat
    Right i can place code in web control. but I am using C# class file to call functions to manipulate data like Mydatafunctions.getdataset(sql) Mydatafunctions.Updaterecord(sql)
    So can i place this file app_code folder in umbraco cms system?
    would this be work after that?
    Feb 01, 2011 @ 14:52
    Jonas Eriksson
    Yes :-)
    Feb 01, 2011 @ 15:55
    pat
    thanks , I have created my user control and add class file to handle data functions and I can embed usercontrol as a macro.
    and its gave me sql query out put. this is very good as my website has complex search , and workflow for buy now process.
    thanks.
