  • Mikael Mørup 297 posts 326 karma points
    Jan 07, 2009 @ 16:39
    Mikael Mørup
    XSLT macro parameter problem
    I'm trying to create a macro with a parameter. The macro should allow me to select a picture from the media lib.
    I added a parameter to the macro, i would like it to be of the mediaPicker type, but that is not available, so i chose the currentMedia type.
    When i run the macro i can select a picture, and it says "updated with ID: 1098, which is the correct media id.
    But when i try to acces the parametervalue in my XSLT like this :
    I get this string : /media/1420/pic1.jpg80060028521jpg
    insted of the mediaId i was hoping for.
    How can i get my mediId from the macro instead?
    Mikael
  • Hal Lesesne 25 posts 25 karma points
    Jan 08, 2009 @ 16:28
    Hal Lesesne
    I think that you actually want the @id attribute of the node /macro/picture/node, however I am getting an error when I try to select /macro/picture/node/@id - not sure why exactly, but the error I get when I switch to umbDebug is something like the following:
    An item of type 'Attribute' cannot be constructed within a node of type 'Root'.
    The full error is
    Error parsing XSLT test.xslt
    at System.Xml.Xsl.Runtime.XmlQueryOutput.ThrowInvalidStateError(XPathNodeType constructorType)
    at System.Xml.Xsl.Runtime.XmlQueryOutput.ConstructInEnumAttrs(XPathNodeType rootType)
    at System.Xml.Xsl.Runtime.XmlQueryOutput.WriteStartAttribute(String prefix, String localName, String ns)
    at System.Xml.Xsl.Runtime.XmlQueryOutput.StartCopy(XPathNavigator navigator, Boolean callChk)
    at System.Xml.Xsl.Runtime.XmlQueryOutput.CopyNode(XPathNavigator navigator)
    at System.Xml.Xsl.Runtime.XmlQueryOutput.WriteItem(XPathItem item)
    at
    Jan 08, 2009 @ 18:20
    Mikael Mørup
    I will give it a go when tomorrow.
    Mikael
    Jan 09, 2009 @ 12:38
    Mikael Mørup
    I have now confirmed that your suggested solution also works for me.
  • Ruald Gerber 20 posts 41 karma points
    Jun 09, 2011 @ 13:28
    Ruald Gerber
    Have the syntax changed? I'm doing something similar and just cant get it to work. Im using Umbraco 4.7.
    Jun 09, 2011 @ 14:03
    Tom Fulton
    Hi Ruald,
    Yes, the syntax has changed - the "node" should be replaced with the alias of your Media Type.  For example if your media type is an image:
    <xsl:value-of select="/macro/picture/Image/@id" />
    Or if you expect different media types you can use a wildcard:
    <xsl:value-of select="/macro/picture/*/@id" />
    Also to get the filename or any other property:
    <xsl:value-of select="/macro/picture/*/umbracoFile" />
    Hope this helps,
    Tom
    Jun 09, 2011 @ 15:19
    Ruald Gerber
    Brilliant, that works!
    Thanks a lot.
