  • Sam 184 posts 209 karma points
    Feb 05, 2011 @ 20:38
    Sam
    Previous and next links to move through same level nodes with sorting
    Hi everyone,
    I am using code from another thread to have previous/next links to move through same level nodes but am trying to move it into templates to apply sorting. Is there a way to apply sorting to this or am I doing this the wrong way? Here's the code:
    <xsl:template match="/">
                    <ul id="prevNextMenu">
                      <xsl:apply-templates select="$currentPage/descendant-or-self::* /PortfolioItem">
                                    <xsl:sort select="@createDate" data-type="text" order="descending" />
                            </xsl:apply-templates>
                    </ul>
    </xsl:template>
    <xsl:template match="PortfolioItem">
    <xsl:variable name="nextId" select="number($currentPage/following-sibling::* [@isDoc]/@id)"/>
    <xsl:variable name="prevId" select="number($currentPage/preceding-sibling::* [@isDoc]/@id)"/>
          <xsl:if test="$prevId &gt; 0">
          <li>
            <a href="{umbraco.library:NiceUrl($prevId)}">Previous</a>
          </li>
        </xsl:if>
        <xsl:if test="$nextId &gt; 0">
          <li>
            <a href="{umbraco.library:NiceUrl($nextId)}">Next</a>
          </li>
        </xsl:if>
    </xsl:template>
    The sorting seems wrong because how can you sort a previous and next link? Perhaps the sorting needs to be applied to the <li> itself.
    Any ideas? Thanks :)
    Sam.
    Feb 05, 2011 @ 21:35
    Sam
    This works perfect but without the sorting:
    <xsl:variable name="nextId" select="number($currentPage/following-sibling::* [@isDoc][1]/@id)"/>
    <xsl:variable name="prevId" select="number($currentPage/preceding-sibling::* [@isDoc][1]/@id)"/>
          <li>
          </li>
        </xsl:if>
          <li>
          </li>
        </xsl:if>
      </ul>
    </xsl:template>
    Not sure what was going wrong in the original post? 'Descendant' should actually say 'ancestor' in my first example.
    Sam.
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Feb 05, 2011 @ 21:44
    Hi Sam,
    That makes more sense (ancestor-or-self::) - also, you've applied the [1] predicate necessary to get only the immediate sibling. Was gonna say that :-)
    The preceding- and following-sibling:: axes always work in document order, so won't work with sorting, unless you create a new sorted node set, and apply templates to that set instead.
    /Chriztian
    Feb 05, 2011 @ 21:56
    Sam
    Thanks Chriztian,
    I did wonder why the [1] was there. On a plus note, document order can be sorted by creation date in umbraco via right click on the tree so no need to sort by createDate in the xslt :)) happy times!
    I was gonna say I actually wanted to build something a bit more complex but I'm still a bit lame at xslt. I have 4 pages so I wanted:
    Page 1) 1 2 3 4 Next
    Page 2) Previous 1 2 3 4 Next
    Page3) Previous 1 2 3 4 Next
    Page4) Previous 1 2 3 4
    ...with the bold menu items being <li class ="selected">. But somehow I think that's a bit too much after reading paging examples with queries and stuff. I will stick at it though! Thanks again :)
    Sam.
  • Josh Reid 182 posts 258 karma points
    Feb 06, 2011 @ 02:28
    Josh Reid
    Hi Sam
    This should be pretty straight fwd, as long as the pages are different nodes and not a queried page set ie 10 items of single list split across 4 pages (though thats possible it's just more maths based than the sepearte nodes approach as follows).
    Note: Just wrote it for you now (un-tested)... You can pass a rootId by macro parameter if you want or defaults to parent of currentPage...
    <!-- The fun starts here -->
    <!-- Input the root you want here -->
    <xsl:variable name="rootId">
      <xsl:choose>
        <xsl:when test="/macro/rootId!=''">
          <xsl:value-of select="/macro/rootId"/>
        </xsl:when>
        <xsl:otherwise>
          <xsl:value-of select="$currentPage/parent::*[@isDoc]/@id"/>
        </xsl:otherwise>
      </xsl:choose>
    </xsl:variable>
    <xsl:variable name="root" select="umbraco.library:GetXmlNodeById($rootId)"/>
    <xsl:if test="$root/* [@isDoc and string(umbracoNaviHide) != '1']">
    <ul class="paging">
      <xsl:for-each select="$root/* [@isDoc and string(umbracoNaviHide) != '1']">
        <xsl:if test="position()=1 and $currentPage!=.">
          <li><a href="{umbraco.library:NiceUrl(./preceding-sibling::* [@isDoc][1]/@id)}">Previous</a></li>
        </xsl:if>
        <li>
          <xsl:if test="$currentPage=.">
            <xsl:attribute name="class">current</xsl:attribute>
          </xsl:if>
            <xsl:value-of select="position()"/>
          </a>
        </li>
        <xsl:if test="position()=last() and $currentPage!=.">
          <li><a href="{umbraco.library:NiceUrl(./following-sibling::* [@isDoc][1]/@id)}">Next</a></li>
        </xsl:if>
    </xsl:for-each>
    </ul>
    </xsl:if>
    Cheers
    Josh
    Feb 06, 2011 @ 16:12
    Sam
    Hi Josh,
    Thanks, the nodes are different pages yes, not 10 per page or anything. No luck with the above though, I have picked the root via macro and no list shows on my page, no error parsing, just no list at all. The xslt saves without error too.
    The nodes are the same (and unique) doctype called 'PortfolioItem', could that help in making this list?
    Sam.
    Feb 06, 2011 @ 21:25
    Josh Reid
    Oh, will test n edit...
    Feb 06, 2011 @ 21:31
    Josh Reid
    Sorry Sam- was going a bit fast for my own good ;)
    The preceding and following siblngs should be relative to the $currentPage not the current item in loop...
    So complete working (tested) code is:
      <xsl:choose>
        </xsl:when>
        <xsl:otherwise>
        </xsl:otherwise>
      </xsl:choose>
    </xsl:variable>
    <ul class="paging">
        <xsl:if test="position()=1 and $currentPage!=current()">
          <li><a href="{umbraco.library:NiceUrl($currentPage/preceding-sibling::* [@isDoc][1]/@id)}">Previous</a></li>
        </xsl:if>
        <li>
          </xsl:if>
          <a href="{umbraco.library:NiceUrl(./@id)}">
          </a>
        </li>
        <xsl:if test="position()=last() and $currentPage!=current()">
          <li><a href="{umbraco.library:NiceUrl($currentPage/following-sibling::* [@isDoc][1]/@id)}">Next</a></li>
        </xsl:if>
    </xsl:for-each>
    </ul>
    </xsl:if>
    Cheers
    Josh
    Feb 06, 2011 @ 22:24
    Sam
    Thanks Josh,
    That's great :))  What I'm using at the moment is this so you end up with:
    Previous | Back to portfolio | Next
    <ul class="prevNext">
          <li>
            <a href="{umbraco.library:NiceUrl($prevId)}">Prev</a><xsl:text>&nbsp;|&nbsp;</xsl:text>
          </li>
        </xsl:if>
          <li>
            <a href="{umbraco.library:NiceUrl($currentPage/parent::* /@id)}">Back to <xsl:value-of select="$currentPage/parent::* /@nodeName"/></a>
          </li>
          <li>
            <xsl:text>&nbsp;|&nbsp;</xsl:text><a href="{umbraco.library:NiceUrl($nextId)}">Next</a>
          </li>
        </xsl:if>
    </ul>
    </xsl:template>
    Regarding the following lines:
    and
    As you mentioned, does the top one mean current item in loop and the bottom one current item in relation to $currentPage? I've never seen the !=. before.
    Thanks.
    Sam.
    Feb 06, 2011 @ 22:38
    Josh Reid
    Oh they actually mean the same thing, one is just easier to type (.) and the other is easier to see.
    Inside a for-each these are the same: . and current() - it is the current item in loop.
    The line I changed (and was referring too) is this:
    It looks like you are all sorted (without paging), hope I helped, mark it solution if it did ;)
    J
    Feb 06, 2011 @ 22:44
    Sam
    Thanks Josh, that's a great help, I'm learning all the time :)
    Sam.
