  • dp_sbbs 25 posts 20 karma points
    Jan 15, 2009 @ 15:03
    dp_sbbs
    RenderTemplate problem
    I need to user the RenderTemplate function in one of my Templates to render the content of a node.
    This is a part of my RenderConten Macro:
    [code]
    [/code]
    The template (1118) looks like this:
    [code]
    AGETITEM field="puffContent1"/>
    Read more
    [/code]
    The UMBRACOGETITEM works fine but the UMBRACO_MACRO fails. The imageID gets the value of a mediapicker property.
    The GetImageByMediaID looks like this:
    [code]
    [/code]
    If I just run the template it works fine but when i try to get it with the RenderTemplate function it fails.
    Any ideas?
