  • DrewJigsaw 12 posts 29 karma points
    Feb 10, 2011 @ 15:06
    DrewJigsaw
    Parsing XML using XSLT in /base
    Hello everyone,
    I've been working on a /base routine that will in theory ingest xml from an external source parse that xml via xslt and chuck out nicely formed xml at the other end. Trouble is I'm still quite new to C# .net development and I'm having to feel my way around the problem.
    This is what I have so far.
    using System;
    using System.Linq;
    using System.Web;
    using umbraco.presentation.umbracobase;
    using umbraco.presentation.Web;
    using System.Xml.XPath;
    using System.Xml;
    using System.Xml.Xsl;
    namespace GeckoBoard.XMLProcessings
        public class Library
            public static XPathNodeIterator Test()
                XmlDocument document = new XmlDocument();
    //Fetch XML over HTTP
                document.Load("http://api.getclicky.com/api/stats/4?site_id=66353141&sitekey=73ba7921526acd12&type=visitors-list&visitor-details=time,uid&date=today&limit=all");
                XslCompiledTransform xslt = new XslCompiledTransform();
    //Load in XSLT (a local path would be better I think?)
                xslt.Load("http://mydomaine/xslt/Test.xslt");
                XmlDocument transform = new XmlDocument();
    //Attempt to pass in the XML document into the transform
                using (XmlWriter writer = transform.CreateNavigator().AppendChild())
                    xslt.Transform(document, null, writer);
    //Return the output
                XPathNodeIterator output = transform.CreateNavigator().Select("/");
                return output;
    At pressent I'm getting an inner exception of "System.IO.IOException: Unable to read data from the transport connection"
    Any ideas anyone has are welcome =)
    Feb 10, 2011 @ 16:29
    Jeroen Breuer
    It seems this error is unrelated to outputting xml with /base. I think the error is in document.load or xslt.load.
    Btw in Umbraco 4.6 you can also output an XmlDocument or XDocument. See this topic: http://our.umbraco.org/forum/developers/api-questions/12058-XPathNodeIterator-loses-CDATA
    Jeroen
    Feb 10, 2011 @ 16:40
    DrewJigsaw
    Thanks for the infomation on XDocument, that could really be useful.
    I did had a feeling the error may be with xslt.load I did try a, for want of a better word, local path but that reasult in a load error also.
    When I input
    xslt.Load("text.xstl");
    I recieved an error that file could not be located at location on the C:// but it bore little resemblece to the location of the file. Is there a better way to specify the location of a local file within a load statement?
