  • Joe 21 posts 41 karma points
    Feb 10, 2011 @ 20:44
    Joe
    Secondary Nav - Exclusion Help
    What I Need: My secondary nav to output only the page titles below Software, Applications, Related Products, Our Clients, and Support.  So, when I click on the Software link from the main nav, a <ul> populated with all page titles below Software should appear below the Software link.  Really, I just want to exclude Home from having a <ul> of second level titles created because it will populate a list that is already seen in the main nav.
    Folder Setup:
    My Secondary Level Nav Code:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
    <xsl:template match="/">
    <!-- The fun starts here -->
    <ul>
    <xsl:for-each select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1'and @nodeTypeAlias!='Home']">
        <li>
            </a>
        </li>
    </xsl:for-each>
    </ul>
    </xsl:template>
    </xsl:stylesheet>
    Feb 10, 2011 @ 21:26
    Hi Joe
    Is this sample how your primary navigation looks?
    If you go to the developer section and create a new XSLT based macro you should be able to choose the "Navigation prototype" from the dropdown. Here you'll find a level macro where you can specify the levels that should be displayed in your secondary navigation.
    I think this should solve your issue? :-)
  • Jason Prothero 422 posts 1243 karma points MVP c-trib
    Feb 10, 2011 @ 22:07
    Jason Prothero
    Is the Document Type of the home page "Home"?
    Or are you trying to check for the name of the node (@nodeName)?
    Feb 10, 2011 @ 22:35
    Joe
    Thanks for the responses guys!
    The image sample above is my current  folder configuration in umbraco.  The source code above is for the secondary nav that I haven't implemented yet.
    Here is how that folder setup renders with my main nav:
    Here is the source code for my main nav:
    <xsl:stylesheet
        version="1.0"
    <!-- Input the documenttype you want here -->
    <!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
    <!-- Use div elements around this macro combined with css -->
    <!-- for styling the navigation -->
    <xsl:variable name="level" select="1"/>
    <!--xsl:for-each select="$currentPage/ancestor-or-self::node [@level=$level]/node [string(data [@alias='umbracoNaviHide']) != '1']"-->
    <xsl:for-each select="umbraco.library:GetXmlNodeById(1045)/node [string(data [@alias='umbracoNaviHide']) != '1']">
            <a href="{umbraco.library:NiceUrl(@id)}" class="navOff">
                <xsl:choose>
                    <xsl:when test="$currentPage/ancestor-or-self::node/@id = current()/@id">
                        <xsl:attribute name="class">navOn</xsl:attribute>
                    </xsl:when>
                    <xsl:otherwise>
                        <xsl:attribute name="class">navOff</xsl:attribute>
                    </xsl:otherwise>
                </xsl:choose>
            </a>
    <!-- Secondary Navigation Tests Here -->
    </xsl:for-each>
    </xsl:template>
    </xsl:stylesheet>
    What I am having trouble with is outputing the second level links below the first level links after the first level link is clicked.
    Does that make sense?
    @Jason - In the first code snippet I attached, I was trying to create a loop that would output second level nav links for all pages except Home.
    Hope this all makes sense - a lot of writing for something so simple! :]
    Feb 11, 2011 @ 23:16
    Jason Prothero
    Is the home page the 1045 id above?
    Feb 11, 2011 @ 23:17
    Joe
    Hi Jason
    Yes, that's right.
    Feb 12, 2011 @ 00:19
    Jason Prothero
    I made a small modification, but I'm not sure it will give you what you want.  Does that get close?
    <xsl:for-each select="umbraco.library:GetXmlNodeById(1067)/node [string(data [@alias='umbracoNaviHide']) != '1']">
                <xsl:choose>
                    </xsl:when>
                    <xsl:otherwise>
                    </xsl:otherwise>
                </xsl:choose>
            </a>
    <xsl:variable name="parent" select="."/>
    <ul>
    <xsl:for-each select="$parent/node [string(data [@alias='umbracoNaviHide']) != '1'and @nodeTypeAlias!='Home']">
        <li>
            </a>
        </li>
    </xsl:for-each>
    </ul>
    </xsl:for-each>
    Why can't you use the base Navigation starter macro (or even the Sitemap macro)?
    I've also used something like this to accomplish what you're trying to do.  Maybe this will help too.
    <ul class="headerNav sf-menu flt">
    <li>
        <xsl:if test="$currentPage/@nodeTypeAlias = 'HomePage'">
            current
        </xsl:if>
    </xsl:attribute>
    <a href="/">Home</a>
    </li>
    <xsl:for-each select="$currentPage/ancestor-or-self::node [@level=$level]/node [string(data [@alias='umbracoNaviHide']) != '1']">
        <li>
                <xsl:if test="count(./descendant-or-self::node[@id = $currentPage/@id]) > 0">
                    current
                </xsl:if>
                </xsl:attribute>
    </a>
            <xsl:if test="count(./child::node) &gt; 0">
                <ul>
                    <xsl:for-each select="./child::node [string(data [@alias='umbracoNaviHide']) != '1']">
                        <li>
    </a>
                        </li>
                    </xsl:for-each>
                </ul>
            </xsl:if>
        </li>
    </xsl:for-each>
    </ul>
    </xsl:template>
    Feb 15, 2011 @ 19:55
    Joe
    @ Jason - Thanks for the reply :)
    I tried your first suggestion, and it was close, but there are a few issues.
    See the image below to see how it rendered.
    You'll notice how it displays all the list items at once. I am trying to make it work so that when I click on, let's say, Related Products, after the click is made, LiftTrainer, Physical Therapy, and SwingTrainer would appear.
    **Only the links with a carrot should appear when the Home page is first loaded.  **Secondary links should appear when their parent is clicked.
    Also, you can see that there are some indentation issues with the level one items (carrot links). Any idea why that would happen? They should all be left justified.
    Feb 15, 2011 @ 20:22
    Jason Prothero
    I think you probably need to change this:
                    current
    </xsl:if>
    To use your navOn/navOff classes
    Also, the secondary nav didn't take into account the umbracoNaviHide.  Try this:
            <xsl:if test="count(./child::node [string(data [@alias='umbracoNaviHide']) != '1']) &gt; 0">
    <ul>
    <li>
    </a>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:if>
    Feb 15, 2011 @ 22:51
    Joe
    Nearly there! The only thing I'm having trouble with now is getting the secondary links to appear only when their parent is clicked.
                    current
    </xsl:if>
    should be used to address the navOn/navOff classes.  Where exactly would that be placed?
    Here is the code that works nicely as a static list:
    <xsl:stylesheet
    version="1.0"
    <xsl:choose>
    </xsl:when>
    <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
    </a>
    <!-- Secondary Nav -->
    <ul>
    <li>
    </a>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:if>
    </xsl:for-each>
    </xsl:template>
    </xsl:stylesheet>
    So, now I just have to figure out how to hide the secondary links until their parent is clicked.
    Feb 18, 2011 @ 17:23
    Joe
    Any ideas on this one?  I still can't get the secondary links to appear only after their parent is clicked. They appear fine as a static list though.
    Thanks!
    Feb 23, 2011 @ 19:55
    Jason Prothero
    Sorry it took me a while to respond...
    How does this work for you?
          <xsl:choose>
            <xsl:when test="count(./descendant-or-self::node[@id = $currentPage/@id]) > 0">
              <xsl:value-of select="'navOn'"/>
            </xsl:when>
            <xsl:otherwise>
              <xsl:value-of select="'navOff'"/>
            </xsl:otherwise>
          </xsl:choose>
        </xsl:attribute>
      </a>
        <ul>
          <li>
            </a>
          </li>
          </xsl:for-each>
        </ul>
      </xsl:if>
    </xsl:for-each>
