Hi, I am very excited with the efficiency of umbraco and the excellent support I get on forums. (Thanks doug!!!). I want to use XML published by a classical ASP page in my XSLT in umbraco. But I don't have any idea how I can do it. I am given a webaddress of a classical ASP page (www.blah.com/test.asp) which outputs standard XML. I have to render this XML in my umbraco website using XSLT. Can someone please help? Thanks in advance, Dharmesh
Hi Dharmesh, umbraco.library:GetXmlDocumentByUrl(url) is what you need to retrieve some xml from external url in your xslt. Regards, /Dirk
Yes, it works fine now. Thanks Dirk for your quick response. Thanks again.
Upload image
Using XML output from webpage in XSLT/Macro
Thanks in advance,
Dharmesh
Hi Dharmesh,
Regards,
/Dirk
Thanks again.
