  • Joe 21 posts 41 karma points
    Feb 18, 2011 @ 21:50
    Joe
    Second Level Navigation - Quick Fix?
    I am trying to get my second level nav links to show up only when their parent is clicked. Right now, all second level nav links are layed out statically beneath their parent.
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <!-- Input the documenttype you want here -->
    <!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
    <!-- Use div elements around this macro combined with css -->
    <!-- for styling the navigation -->
    <xsl:variable name="level" select="1"/>
    <xsl:template match="/">
    <!-- The fun starts here -->
    <xsl:for-each select="umbraco.library:GetXmlNodeById(1045)/node [string(data [@alias='umbracoNaviHide']) != '1']">
    <a href="{umbraco.library:NiceUrl(@id)}" class="navOff">
    <xsl:choose>
    <xsl:when test="$currentPage/ancestor-or-self::node/@id = current()/@id">
    <xsl:attribute name="class">navOn</xsl:attribute>
    </xsl:when>
    <xsl:otherwise>
    <xsl:attribute name="class">navOff</xsl:attribute>
    </xsl:otherwise>
    </xsl:choose>
    </a>
    <!-- Secondary Nav -->
    <xsl:if test="count(./child::node [string(data [@alias='umbracoNaviHide']) != '1']) &gt; 0">
    <ul>
    <xsl:for-each select="./child::node [string(data [@alias='umbracoNaviHide']) != '1']">
    <li>
    </a>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:if>
    </xsl:for-each>
    </xsl:template>
    </xsl:stylesheet>
  • kows 81 posts 151 karma points c-trib
    Feb 19, 2011 @ 18:56
    kows
    add a check to your xsl:if for second nav if $currentPage equals the selected node (same test for your class)...?
    Feb 19, 2011 @ 19:35
    Kim Andersen
    Hi Joe
    Try changing your xsl:if to this:
    <xsl:if test="count(./child::node [string(data [@alias='umbracoNaviHide']) != '1']) &gt; 0 and count(descendant-or-self::node [@id = $currentPage/@id]) &gt; 0">
    Does that help?
    /Kim A
