Retrieving XML data from a node property using XSLT
I have a user control which serializes a List<> and stores the data in a node property as XML. so my node/data [@alias = 'nodeAssociation'] contains the following value:
for some reason, I cannot work with this XML data in my XSLT. i.e.
Works
never works. does any one know of a way i could this?
Works
It is storing into the node as text. In your data type, you will need to override the ToXml to be a node, versus a text object.
[code]
public override XmlNode ToXMl(System.Xml.XmlDocument xd)
if ((base.Value + "") != "")
XmlDocument doc = new XmlDocument();
doc.LoadXml(base.Value.ToString());
XmlElement xe = xd.CreateElement(doc.SelectSingleNode("/Pair").Name);
xe.InnerXml = doc.SelectSingleNode("/Pair").InnerXml;
return xe;
return xd.CreateTextNode("");
[/code]
This can probably be cleaned up a bit, but, I broke it down when having a problem at one point.
