Topic author was deleted
I am having trouble with looping through all items which have the same tags.
<xsl:for-each select="tags:getEverythingWithTags('test')"> <xsl:value-of select="current()/@nodeName"/> </xsl:for-each><xsl:copy-of select="tags:getEverythingWithTags('test')"/> gives me following output<root><node id="1076" parentID="1057" level="2" writerID="0" sortOrder="7" createDate="2011-01-04T22:18:20" nodeName="Ap" path="-1,1057,1076" /><node id="1077" parentID="1057" level="2" writerID="0" sortOrder="0" createDate="2011-01-04T22:18:40" nodeName="Mt" path="-1,1057,1077" /></root>What am i doing wrong?Thnx
Hi Bart
try changing the value-of to this
<xsl:value-of select="current()/root/node/@nodeName" /> or <xsl:value-of select="current()/node/@nodeName" /> perhaps.
Does this help?
Comment author was deleted
Hi Jan,
I get an output wehn i use:
<xsl:for-each select="tags:getEverythingWithTags('test')"> <xsl:value-of select="current()/root/node/@nodeName" /> </xsl:for-each>
but only the first node of the 2 nodes is shown.
But in the XML output you posted in the first post you also only got 2 <node> elements returned, right?
Are there more than 2 posts tagged with "test"?...
Just checked the output of <xsl:copy-of select="tags:getEverythingWithTags('test')"/> with the xslt viewer and discoverdthat the node isn't closed correctly
Bart
So there should actually be 3 nodes?
Have you tried to go to the "Content" node and right click it choosing "Republish entire site"? (this updates the XML cache)
Just to make sure that the XML is properly structured. You could also check to see if there is XML in the umbraco.config that is not wellformed.
Hi Bart (& Jan)
The XSLT Visualizer munges the output - you have to wrap a textarea around stuff you copy-of, in order to see the correct output.
It seems you're just getting the tagged nodes wrapped in a root element, which means that you should modify your for-each to something like this:
<xsl:for-each select="tags:getEverythingWithTags('test')/root/node"> <xsl:value-of select="@nodeName"/> </xsl:for-each>
/Chriztian
Hi Chriztian,
That work fine.
Thnx a lot
for each loop tags library
</xsl:for-each>
Thnx
Hi Bart
Does this help?
Hi Jan,
</xsl:for-each>
<root>
</root>
Hi Bart
Hi Jan,
<node id="1076" parentid="1057" level="2" writerid="0" sortorder="7" createdate="2011-01-04T22:18:20" nodename="Ap" path="-1,1057,1076">
<node id="1077" parentid="1057" level="2" writerid="0" sortorder="0" createdate="2011-01-04T22:18:40" nodename="Mt" path="-1,1057,1077">
Bart
Hi Bart (& Jan)
<xsl:for-each select="tags:getEverythingWithTags('test')/root/node"> <xsl:value-of select="@nodeName"/> </xsl:for-each>/Chriztian
Hi Chriztian,
That work fine.
Thnx a lot
