  • ad de Vos 25 posts 46 karma points
    Feb 25, 2011 @ 14:18
    ad de Vos
    getMedia, Value was either too large or too small for an Int32.
    Hi, I know there are a few topics about this, but the solutions are not working for me.
    I have a documenttype with an upload field.
    I have a XSLT script to display newsitems with image. When i do not have an image then all works fine, when i upload an image i get the error above. It´s failing on the code below:
       <xsl:choose>
                  <xsl:when test="current()/newsImage != ''">
      <xsl:if test="string-length(current()/newsImage) &gt; 0">
      <xsl:variable name="media" select="umbraco.library:GetMedia(current()/bannerImage, 'false')" />
                        <img src="{$media/umbracoFile}" alt="klik hier voor het nieuwsbericht" width="84" border="0"/>
    </xsl:if>
                      </xsl:when>
        <xsl:otherwise>
       <img src="/media/6468/empty.png" alt=""  width="84" border="0"/>
      </xsl:otherwise>
     </xsl:choose>
    Does sombody can help me with this.?
    Thank you. Kind regards,
    Ad
    Feb 25, 2011 @ 14:27
    Tom Fulton
    To avoid this error you typically test to see if the media picker property is empty.  It looks like you are doing that for newsImage but not for bannerImage?  Are you maybe mixing up the two names?
    Try..
      <xsl:choose>
        <xsl:when test="current()/bannerImage != ''">
        </xsl:when>
        <xsl:otherwise>
        </xsl:otherwise>
      </xsl:choose>
    Tom
    Feb 25, 2011 @ 14:35
    ad de Vos
    Thank you. I had pasted a solution but did not alter the names... but when i change the names it still wont work...
    Feb 25, 2011 @ 14:40
    Tom Fulton
    Are you still getting the error or is the image just not showing?
    Is the correct property bannerImage or newsImage?
    Is this code running inside a for-each loop?
    -Tom
    Feb 26, 2011 @ 10:00
    Kim Andersen
    2
    Hi Ad
    If you are using a upload data type, then you shall not use the GetMedia-extension. The upload data type returns the path to the image directly to you, so that could be a reason to why the extension fails.
    /Kim A
    Feb 28, 2011 @ 11:55
    ad de Vos
    Thank you, that was it.. just referenced the field and it worked like a charm... Got a lot to learn...
    Feb 28, 2011 @ 16:11
    Kim Andersen
    Great to hear that you got things worked out Ad.
    Sometimes it can be a good idea to print out the currentPage to see how the XML looks. You can do this like this:
    <textarea>
    <xsl:copy-of select="$currentPage" />
    </textarea>
    /Kim A
    Feb 28, 2011 @ 16:14
    ad de Vos
    Great Tip! tnx
    Feb 28, 2011 @ 16:17
    Kim Andersen
    Yeah, it gives you a good idea on what to do with the different data.
    For this purpose you could maybe also try out the XML Dump package from Chriztian Steinmeier. But the textarea-trick does a great job as well :)
    /Kim A
