The question is this. How can a content manager move the macro after the content has been saved? For example if they decide that their formatted content should appear next to a different paragraph in the content. From what I can see, it's not possible to select the macro and drag it around the content. The only way I've found to move it is to use html view and copy/paste the
This might be a silly thought, but can you move the text around the macro? Not very intuitive for the users but better than having them go in the source view.
That works actually - thanks! Dunno why I didn't think of it before. Still, it's not quite what you'd like to see happen, but at least it means that the client can control the position of the macro. I also notice that you can't remove the macro after you've added it - any ideas on that one?
You can remove the macro... but selecting it so that it can be removed (or the properties edited) seems to be impossible in Safari/Mac from my own experience, though I've not done a thorough test. If you can reproduce please enter a bug in codeplex.
XSLT macros inserted in RTE - how to move them without using source view?
Hi all,
I've created an xslt macro to be used in the richtext editor. It works great:
using macros with the richtext editor to give more control over content
I'm using Umbraco v4.0.1.
David
Hi David,
Lesley
Hi Lesley,
David
cheers,
doug.
Thanks Doug,
This is a problem with IE7 only - it works fine in Firefox.
I've created a bug on codeplex here:
Cannot select/edit/move macro content in Tiny MCE in IE7 (v4.0.1)
David
