I'm using the multiple textstring datatype from ucomponents to create two lists.
I'm trying to output it with this XSLT but it doesnt work.. any ideas why?
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " ">]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets"> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <xsl:template match="fordele | ulemper"> <ul> <xsl:apply-templates/> </ul> </xsl:template> <xsl:template match="fordele"> <li><xsl:value-of select="."/></li> </xsl:template> </xsl:stylesheet>
Here is the XML:
<root id="-1"><Forside><Tekstside id="1081" level="3" nodeName="Test" urlName="test"> <umbracoRedirect /> <overskrift>Test</overskrift> <tekst></tekst> <sidensTitel /> <sidensBeskrivelse /> <sidensNgleord /> <Faktaboks id="1113" level="4" nodeName="Det her virker" urlName="det-her-virker"> <umbracoNaviHide>1</umbracoNaviHide> - <fordele> <values> <value>Ingen emission</value> <value>Det virker bare</value> <value>Det er top nice</value> <value>Det er bare fedt</value> <value>Udstødnings</value> <value /> </values> </fordele> <ulemper> <values> <value>Giver sygdom</value> <value>Er farligt</value> <value /> </values> </ulemper> </Faktaboks></Tekstside></Forside></root>
<root id="-1">
<Forside>
This works for outputting the "fordele", but would be nice to be able to output both in same xslt file - and still have them seperated as two lists
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " ">]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets"> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <xsl:template match="/"> <ul> <xsl:apply-templates select="$currentPage/Faktaboks/fordele" /> </ul> </xsl:template> <xsl:template match="value"> <li><xsl:value-of select="."/></li> </xsl:template> </xsl:stylesheet>
Got a little further, but got a tiny issue still - it seems to be outputting the "1" from the element when using this XSLT:
Another problem is that I cant give the UL different classes - so I guess I have to create two XSLT files for this job? :)
version="1.0" encoding="UTF-8"?>DOCTYPE xsl:stylesheet [ ENTITY nbsp " ">]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets"> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <xsl:template match="/"> <xsl:apply-templates select="$currentPage/Faktaboks" /> xsl:template> <xsl:template match="fordele|ulemper"> <ul> <xsl:apply-templates/> ul> xsl:template> <xsl:template match="value"> <li><xsl:value-of select="."/>li> xsl:template> xsl:stylesheet>
Hi Daniel
What do you mean by the "1"?
I'm not sure...but woul'nt you somehow be able to set different class names like this...
<ul><xsl:if test="name(.) = 'fordele'"><xsl:attribute name="class">fordele</xsl:attribute></xsl:if> <xsl:if test="name(.) = 'ulemper'"> <xsl:attribute name="class">ulemper</xsl:attribute> </xsl:if>
<!-- your apply template here -->
</ul>
Does this work?
Hi Daniel,
These templates will work - you definitely won't need two files for that; and for the separate classes - well :-)
<xsl:template match="/"> <xsl:apply-templates select="$currentPage/Faktaboks" /> </xsl:template> <xsl:template match="Faktaboks"> <xsl:apply-templates select="fordele | ulemper" /> </xsl:template> <xsl:template match="fordele | ulemper"> <ul class="{name()}"> <xsl:apply-templates/> </ul> </xsl:template> <xsl:template match="value"> <li> <xsl:value-of select="."/> </li> </xsl:template>
/Chriztian
Thanks guys - Chriztian that worked totally as i wanted it :-)
Unordered lists XSLT wont work
Here is the XML:
ENTITY nbsp " ">
<xsl:stylesheet
version="1.0"
xsl:template>
<ul>
ul>
xsl:template>
xsl:template>
xsl:stylesheet>
Hi Daniel
<ul>
</xsl:if>
</xsl:if>
</ul>
Does this work?
Hi Daniel,
/Chriztian
