I have a site set up in the following fashion:
Home (login)
--company a
-----sub 1
-----sub 2
-----sub 3
--company b
-----sub1
Now on the company a and company b pages I have an uploaded to upload the company logo. I have placed the upload to go right above my sidebar navigation. Now I know I can just use the page field in the code and get the image to show up above the sidebar, but then it goes away when I am on the sub pages. What I need to do is pull in the image from the company a and company b pages in my xslt for my navigation. Here is my navigation as it stands now, this works, it shows company a and its sub children when in the company a section of the site, and vice versa for company b.
[quote=jhauge]Looks absolutely right to me, I would look for typos. Not sure why you're putting it in a xsl:for-each though.
BTW I prefer this syntax for xsl-values in img-tag attributes:
I believe your syntax results in a , when outputting xml.
Regards
Jesper Hauge[/quote]
I decided to break away from using my navi and making my own xslt for the company logo and placing the macro above the sidebar navigation. Now I am still getting blank img src for some reason. Here is the code I am trying, I know the alias is correct as I copied and pasted from the doc type. What could be causing this? I am trying 2 different options to see which one works and neither are working right now, thats why there are 2 different img src that do the same thing with different syntax...
[code]
Probably not extreme but need some XSLT help
Home (login)
--company a
-----sub 1
-----sub 2
-----sub 3
--company b
-----sub1
version="1.0"
Now I just need to use the root node (which points to either company a or company b) and grab the image that is uploaded.
Someone should be able to help you with a better solution, but you could check to see what level of nav you are on and move up to the correct parent
(typed in to forum, probably has errors!)
[code]
I am getting closer, if I use:
as a test phrase I can get the root page body text on all of the sub pages and it works just as it should, however when i try and do this:
I am getting an empty img src. I am using an upload field for the image with the alias companyLogo, what could I be doing wrong to not get the image?
anyone know why it wont show? I am pulling my hair out over here :)
Regards
Jesper Hauge
Regards
[code]
version="1.0"
[/code]
I figrued it out it was a spelling mistake...
