  • ask 28 posts 48 karma points
    Mar 03, 2011 @ 15:31
    ask
    get images using mediacurrent
    hello folks,
    i have placed my images(10 images) in folder(gallery) in mediacurrent.
    how do i loop through all the images in the folder.
    i am using umbraco version 4.6.1
    thank you
    Mar 03, 2011 @ 20:54
    Kim Andersen
    Hi Ask
    Could you explain in more details what you want to achieve? I get that you want to loop through images in a folder in the media gallery, but where do you get the folder from? Are you using a media picker on a node, or is the folder comming from a macro parameter?
    If you have some existing code you could show us, it would be great so that we can make that work :)
    /Kim A
    Mar 04, 2011 @ 02:53
    ask
    i am unable to edit this question..
    i have  created folder(named as gallery) under media section in umbraco backend and  will be adding images under this folder.
    then i am creating a xslt macro with parameter "mediacurrent".
    i will choose this folder(gallery) as source.
    i would like to have script for looping through images in that selected folder or something like that .
    thank you
    Mar 04, 2011 @ 08:17
    Kim Andersen
    Hi Ask
    I can't remember what the mediaCurrent type returns, but could you try to print out whats in the parameter like this:
    <textarea>
    <xsl:copy-of select="macro/aliasOfTheMediaCurrent" />
    </textarea>
    Then we can see what we have to work with.
    /Kim A
    Mar 04, 2011 @ 15:00
    ask
    it returns as like this if i choose folder in the media section of umbraco backend
    <ImageSource>
      <Folder id="1127" version="96be8528-ad92-4904-8b17-5e8499886d48" parentID="-1" level="1"
    writerID="0" nodeType="1031" template="0" sortOrder="53" createDate="2011-03-03T19:38:41" updateDate="2011-03-03T19:38:41"
    nodeName="gallery" urlName="gallery" writerName="admin" nodeTypeAlias="Folder"
     path="-1,1127">
        <contents />
      </Folder>
    </ImageSource>
    Mar 04, 2011 @ 15:46
    Kim Andersen
    Hi Ask
    Could you try something like this then:
    <xsl:variable name="mediaNode" select="macro/aliasOfTheMediaCurrent" />
    <xsl:variabel name="id" select="$mediaNode/ImageSource/Folder/@id" />
    <xsl:variable name="folderContent" select="umbraco.library:GetMedia($id,1)" />
    Now the $folderContent should (if I didn't make any mistakes :) ) contain all of the XML that the selected folder contains, and you can run through the child nodes from there.
    Does that make sense?
    /Kim A
    Mar 07, 2011 @ 08:10
    ask
    Hi kim,
    i tried this way
    <xsl:variable name="mediaNode" select="/macro/mediaSource" />
      <xsl:variable name="id" select="$mediaNode/Folder/@id" />
    <xsl:if test="$id">
      <xsl:value-of select="$folderContent"/>
             <img src="{$folderContent}" alt="" height="200px" width="200px"/>
    </xsl:if>
    i got this output
    /media/4119/img-1.jpg24413733015jpg/media/4127/img-3.jpg24413732463jpg/media/4137/img-7.jpg11313011397jpg
    what should be schema  for newer version?
    i need to assign each image path to image src.
    thank you
    Mar 07, 2011 @ 08:19
    Kim Andersen
    Try something like this:
    <xsl:if test="$id">
    <xsl:for-each select="$folderContent/Image">
    <img src="{umbracoFile}" alt="@nodeName" />
    </xsl:for-each>
    </xsl:if>
    I haven't tried the above piece of code, but if this doesn't work, please try to print out the $folderContent variable in a textarea, and show us the returned XML :)
    /Kim A
    Mar 07, 2011 @ 08:21
    Hi Ask
    You can read more about using the GetMedia extension here: http://our.umbraco.org/wiki/reference/umbracolibrary/getmedia
    About the schema...when Umbraco 4.5 was released the XML schema was changed so the XSLT that needs to be written with 4.5 and above should have another syntax than the old schema. This is something that is confusing many people who are new to Umbraco since there are many examples on how to achieve stuff with XSLT in Umbraco using the old schema syntax. This is not an issue here since you get the image properties outputted.
    What you need to do to create a list of the images now is this
    <xsl:if test="$id">
    <xsl:for-each select="$folderCOntent">
    <ul>
    <li><img src="{umbracoFile}" alt="" height="200px" width="200px"/></li>
    </ul>
    </xsl:for-each>
    </xsl:if>
    Try it out - it should to what you're requesting.
    Mar 22, 2011 @ 15:07
    ask
    thank you Mr.kim && Mr.Jan
    Mar 22, 2011 @ 20:55
    Kim Andersen
    Ahh great news hearing from you Ask :)
    I'm glad that the solution above worked for you.
    /Kim A
    Mar 22, 2011 @ 21:46
    Hi Ask
    Happy to hear you got it solved. Just out of couriosity...what does your working code look like now? :-)
