I've seen some examples in the forum but haven't gotten any of them to work with my xslt navigation.
<xsl:output method="xml" omit-xml-declaration="yes" /> <xsl:param name="currentPage"/> <xsl:variable name="level" select="1"/> <xsl:template match="/"> <li> <a href="/">Home</a> </li> <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(showInNavigation) = '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id"> <xsl:attribute name="class">active</xsl:attribute> </xsl:if> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each> </xsl:template>
This is what I have so far. As you can see the 'home' button is outside the loop and therefore not highlighted when clicked like the other pages. How can I incorporate the 'home' button into the navigation of the sub nodes?
I appreciate your help!
I'm sorry for beeing too hasty, I solved it myself. I added this line above template:
<xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::*[@level = 1]" />
And added this before the for each loop:
<!-- Home node added here --> <li> <a href="{umbraco.library:NiceUrl($siteRoot/@id)}"> <xsl:if test="$currentPage/@id = $siteRoot/@id"> <xsl:attribute name="class">active</xsl:attribute> </xsl:if> <xsl:value-of select="$currentPage/ancestor-or-self::*/@nodeName"/> </a> </li>
This is the final code of my top navigation menu which highlights the home link:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets "> <xsl:output method="xml" omit-xml-declaration="yes" /> <xsl:param name="currentPage"/> <xsl:variable name="level" select="1"/> <xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::*[@level = 1]" /> <xsl:template match="/"> <!-- Home node added here --> <li> <a href="{umbraco.library:NiceUrl($siteRoot/@id)}"> <xsl:if test="$currentPage/@id = $siteRoot/@id"> <xsl:attribute name="class">active</xsl:attribute> </xsl:if> <xsl:value-of select="$currentPage/ancestor-or-self::*/@nodeName"/> </a> </li> <!-- Sub nodes added here --> <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(showInNavigation) = '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id"> <xsl:attribute name="class">active</xsl:attribute> </xsl:if> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each> </xsl:template></xsl:stylesheet>
I hope someone will find this useful.
Maybe an admin want to check this thread as solved? :)
Upload image
Highlight 'home' link in navigation
