  • Connie DeCinko 931 posts 1160 karma points
    Mar 10, 2011 @ 21:55
    Connie DeCinko
    Help with dynamic XSLT for menus
    I have the XSLT below which always create three levels of menu, always starting at a specific level.  I want to change it so that:
    If the current page (no matter how deep) has children, show PARENT / SELF / CHILDREN as the three levels.
    If the current page (no matter how deep) has no children, show GRANDPARENT / PARENT / SELF as the three levels.
    In both cases, never go any higher than the highest page using template=1165.
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
    <xsl:template match="/">
      <xsl:if test="count($currentPage/ancestor-or-self::* [@template=1165 and string(umbracoNaviHide) != '1']) &gt; 0">
        <div class="block">
          <xsl:for-each select="$currentPage/ancestor-or-self::* [@template=1165 and string(umbracoNaviHide) != '1']">
            <h3>
              </a>
            </h3>
          </xsl:for-each>
          <ul class="products">
            <xsl:for-each select="$currentPage/ancestor-or-self::* [@template=1165 and string(umbracoNaviHide) != '1']/* [@isDoc and string(umbracoNaviHide) != '1']">
              <xsl:variable name="subItems" select="umbraco.library:GetXmlNodeById(@id)/child::* [@isDoc and string(umbracoNaviHide) != '1']"/>
              <li>
                <xsl:if test="count($subItems)">
                  <xsl:attribute name="class">open</xsl:attribute>
                </xsl:if>
                </a>
                  <ul>
                    <xsl:for-each select="$subItems">
                      <xsl:variable name="subSubItems" select="umbraco.library:GetXmlNodeById(@id)/child::* [@isDoc and string(umbracoNaviHide) != '1']"/>
                      <li>
                        </a>
                        <xsl:if test="count($subSubItems)">
                          <ul>
                            <xsl:for-each select="$subSubItems">
                              <li>
                                </a>
                              </li>
                            </xsl:for-each>
                          </ul>
                        </xsl:if>
                      </li>
                    </xsl:for-each>
                  </ul>
                </xsl:if>
              </li>
            </xsl:for-each>
          </ul>
      </xsl:if>
    </xsl:template>
    </xsl:stylesheet>
